chtMultiRegionFoam: problem with the tutorial
Old   April 5, 2012, 11:12
Default chtMultiRegionFoam: problem with the tutorial
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am trying to learn to use the chtMultiRegionFoam and I am starting with the tutorial.
The 1st tutorial I wanted to run is the multiRegionHeater.
I enter the dir of the case and I give the command:
./Allrun
I get this error:
lab@lab-laptop:~/Scrivania/multiRegionHeater$ ./Allrun
Running blockMesh on /home/lab/Scrivania/multiRegionHeater
Running topoSet on /home/lab/Scrivania/multiRegionHeater
Running splitMeshRegions on /home/lab/Scrivania/multiRegionHeater
Running chtMultiRegionFoam in parallel on /home/lab/Scrivania/multiRegionHeater using 2 processes
--> FOAM FATAL ERROR:
No times selected
    From function reconstructPar
    in file reconstructPar.C at line 139.
FOAM exiting
No times selected
FOAM exiting
No times selected
FOAM exiting
No times selected
FOAM exiting
No times selected
FOAM exiting
creating files for paraview post-processing
created 'multiRegionHeater{bottomAir}.OpenFOAM'
created 'multiRegionHeater{topAir}.OpenFOAM'
created 'multiRegionHeater{heater}.OpenFOAM'
created 'multiRegionHeater{leftSolid}.OpenFOAM'
created 'multiRegionHeater{rightSolid}.OpenFOAM'
Do you know what's wrong and what I should do?
Also, where can I find an explanation of this solver, since I guess it is a bit difficult to set everything properly?
Thanks,
Samuele
samiam1000 is offline   Reply With Quote
Old   April 5, 2012, 11:53
Retired Super Moderator
Bruno Santos
Greetings Samuele,
The Allrun script uses a method of keeping a log of every application that is executed. If you look into the files "log.*", you should find the reason why things aren't working as expected.
As for documentation, I'm not familiar with any document online for the "chtMultiRegion*Foam" solvers, so I suggest that you search for it
Failing that, start studying the files that the tutorial case has, as well as looking at the code for the solver itself.
Best regards,
Bruno
Old   April 6, 2012, 02:59
Samuele Z
I looked at the different log files and I noticed that there are problems in the log.chtMultiRegionFoam and in the log.reconstructPar.
These are the 2 files:
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.0-0bc225064152
Exec   : chtMultiRegionFoam -parallel
Date   : Apr 05 2012
Time   : 16:55:55
Host   : "lab-laptop"
PID    : 7962
[0] --------------------------------------------------------------------------
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[0]
[0] --> FOAM FATAL ERROR:
[0] "/home/lab/Scrivania/multiRegionHeater/system/decomposeParDict" specifies 4 processors but job was started with 2 processors.
[0]
FOAM parallel run exiting
[0]
mpirun has exited due to process rank 0 with PID 7962 on
node lab-laptop exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
and
Exec   : reconstructPar -region rightSolid
Date   : Apr 05 2012
Time   : 16:55:56
Host   : "lab-laptop"
PID    : 7968
Case   : /home/lab/Scrivania/multiRegionHeater
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Actually, I do have 2 processors and I don't know why it doesn't work. How can I make it run on a single processor? What I should do. Could anyone help?
Thanks a lot,
Samuele
Old   April 6, 2012, 14:48
Bruno Santos
Hi Samuele,
You didn't specify if you had changed anything in the simulation case. Anyway, here are the steps to fix things:
  1. Run Allclean:
    ./Allclean
  2. Edit the file Allrun and find the following line:
    runParallel `getApplication` 4
    The last number is the number of parallel processes to be used for running in parallel. Change this if you have to. I'll assume you want to use 2 processes.
  3. Edit the file "system/decomposeParDict" and find this line:
    numberOfSubdomains  4;
    Change the number 4 to 2 as well, or whichever number you want to use. And keep the "method" in "scotch" mode:
    method          scotch;
  4. Run Allrun once again.
Best regards,
Bruno
Old   April 10, 2012, 03:22
Samuele Z
Hi Bruno and thanks for answering.
The steps you suggested make the tutorial work fine.
Thanks a lot,
Samuele
Old   June 5, 2012, 08:54
jam
Alain Martin
jam is on a distinguished road
I does not work for me.
In the processor* directories, I don't have any time directories after the run except 0/ and constant/
processor0:
0 constant
processor1:
0 constant
processor2:
0 constant
processor3:
0 constant
All the time dir are in the base dir
0 10 20 30 Allclean Allrun ....... constant makeCellSets.setSet processor0 processor1 processor2 processor3 README.txt system
This is with Ubuntu 10.04
Everything else is ok and this was working with older version.
Any suggestions?
Thanks
This is written in a log file with mpirunDebug
*** An error occurred in MPI_Init
*** before MPI was initialized
*** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
jam is offline   Reply With Quote
Old   June 6, 2012, 16:11
Bruno Santos
Greetings Alain,
Can you be a bit more specific?
  1. Are you 100% certain it's Ubuntu 10.04? Or is it 12.04?
  2. What OpenFOAM version are you talking about? Is it 2.1.1?
  3. Are you using the deb package version? Namely this one: http://www.openfoam.org/download/ubuntu.php ?
  4. Are you running the tutorial case "heatTransfer/chtMultiRegionFoam/multiRegionHeater"?
  5. What's the error message in file "log.chtMultiRegionFoam"?
Best regards,
Bruno
Old   June 7, 2012, 05:44
Samuele Z
Dear Alain,
I suggest you to try to run the case on a single processor.
Than you can try to parallelize it!
Samuele
Old   June 7, 2012, 18:00
Lightbulb
jam
Alain Martin
@wyldckat
1. It is 10.04
2. 2.1.0
3. From the deb pkg
4. All parallel tutorials give the same messages
mpirun -np 4 xxxxxx works as expected but the work is not distributed
mpirun -np 4 xxxxxx -parallel gives the error messages
I went back to the previous version 2.0.0 and everything is ok.
Old   June 8, 2012, 16:38
Bruno Santos
Hi Alain,
OK, it would be really useful to see a good log with errors, so it can be easier to diagnose the real error. Please run mpirun in a similar way to this:
mpirun -n 4 interFoam -parallel > log.interFoam 2>&1
This way the errors are also sent to the main log file. Then search and replace any sensitive data on the log.
Then compress the file:
tar -czf log.interFoam.tar.gz log.interFoam
And attach the compressed file "log.interFoam.tar.gz" to your next post.
Another thing you can look at is if there is any folder and/or file present at "~/.OpenFOAM/", which is where OpenFOAM will look for global configuration files for the user.
Best regards,
Bruno
Old   June 9, 2012, 16:10
jam
Alain Martin
I found the only method that works so far with my setup:
http://www.cfd-online.com/Forums/ope...12-04-lts.html
All others (2.1.1 deb pkg , 2.1.1 tgz source) are not compiling or running as they should.
Only the 2.1.x from git works flawlessly.
Thanks for the suggestions anyway.
Old   October 16, 2013, 20:50
Mominul MuKuT
mukut is on a distinguished road
In my case, the tutorial works fine, but after modifying the geometry by topoSetDict, after running Allrun script I have found following errors in log files as shown below:
log.reconstructPar
|  \\    /   O peration     | Version:  2.2.1                                 |
Build  : 2.2.1-57f3c3617a2d
Exec   : reconstructPar -allRegions
Date   : Oct 16 2013
Time   : 19:53:41
Host   : "mukut-Endeavor-MR3300"
PID    : 5013
Case   : /home/mukut/OpenFOAM/mukut-2.2.1/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater
nProcs : 1
Create time
No times selected
    in file reconstructPar.C at line 178.
FOAM exiting
Date   : Oct 16 2013
Time   : 16:15:49
PID    : 4242
nProcs : 4
Slaves :
3
"mukut-Endeavor-MR3300.4243"
"mukut-Endeavor-MR3300.4244"
"mukut-Endeavor-MR3300.4245"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
Create time
Create fluid mesh for region bottomAir for time = 0
Create fluid mesh for region topAir for time = 0
Create solid mesh for region heater for time = 0
[0]
[0]
[0] Cannot find file "points" in directory "heater/polyMesh" in times 0 down to constant
[0]
[0]     From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&)
[0]     in file db/Time/findInstance.C at line 203.
[0]
[0]
with errorcode 1.
[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Cannot find file "points" in directory "heater/polyMesh" in times 0 down to constant
[1]
[1]     From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&)
[1]     in file db/Time/findInstance.C at line 203.
[1]
[1]
[2]
[2]
[2] --> FOAM FATAL ERROR:
[2] Cannot find file "points" in directory "heater/polyMesh" in times 0 down to constant
[2]
[2]     From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&)
[2]     in file db/Time/findInstance.C at line 203.
[2]
[2]
[3]
[3]
[3] --> FOAM FATAL ERROR:
[3] Cannot find file "points" in directory "heater/polyMesh" in times 0 down to constant
[3]
[3]     From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&)
[3]     in file db/Time/findInstance.C at line 203.
[3]
[3]
mpirun has exited due to process rank 0 with PID 4242 on
node mukut-Endeavor-MR3300 exiting without calling "finalize". This may
[mukut-Endeavor-MR3300:04241] 3 more processes have sent help message help-mpi-api.txt / mpi-abort
[mukut-Endeavor-MR3300:04241] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Besides, there is no time directory inside processors 0~3 directory.
Best regards,
Mukut
mukut is offline   Reply With Quote
Old   October 17, 2013, 14:38
Bruno Santos
Hi Mukut,
Not much information to work with. All I can guess is:
  1. There is nothing to reconstruct, which is why reconstructPar gave you that message.
  2. The solver is complaining about a missing mesh region. Either you:
    1. Have not updated the file that defines which regions are to be used on solid and on fluid;
    2. or something went wrong when you ran decomposePar;
    3. or you did not split up the mesh into the dedicated regions.
The output of topoSet and the content of "topoSetDict" would help understand things a bit better.
Best regards,
Bruno
Old   October 17, 2013, 20:06
Mominul MuKuT
Thank you Mr. Bruno,
I found some mistakes in fvSchemes and fvSolutions file of a region that I have created after modifying the tutorial geometry and I have corrected those. Now simulation is going on but it takes long time, I have modified the controlDict as follows to complete simulation in a shorter time...
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
libs
    "libcompressibleTurbulenceModel.so"
    "libcompressibleRASModels.so"
application     chtMultiRegionFoam;
startFrom       latestTime;
startTime       0.1;
stopAt          endTime;
endTime         0.2;
deltaT          0.1;
writeControl    adjustableRunTime;
writeInterval   0.1;
purgeWrite      0;
writeFormat     binary;
writePrecision  8;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
maxCo           0.3;
// Maximum diffusion number
maxDi           10.0;
adjustTimeStep  yes;
Almost 18hrs gone, now simulation time showed 0.125983 and end time is 0.2
How can I reduced the time of simulation?
Best regards,
mukut
Originally Posted by wyldckat View Post
Hi Mukut,
Best regards,
Bruno
Old   October 18, 2013, 03:55
Bruno Santos
Quick answer: Sorry, not enough information to work with here
Knowing the characteristics of the mesh and the solver used, as well as the contents of the "fv*" files, and how exactly you are running the case, would help.
Old   October 24, 2013, 03:54
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
i have question here, your time step is 0.1s who your solver computes for time with another step ?
one way for reducing time is reducing number of cells especially in axis with small variation, then you can refine your mesh based on results of coarse mesh, you can find this method in openFoam user manual in chapter two i think.
Good Luck,
Ahmed Khattab is offline   Reply With Quote
Old   October 24, 2013, 04:12
Mominul MuKuT
Thanks for reply. I have changed to steady state solver: chtMultiRegionSimpleFoam. Now it worked with my modified geometry.
Old   March 27, 2014, 09:01
Derek Mitchell
derekm is on a distinguished road
Hi Samuele,
  1. Run Allclean:
    ./Allclean
    method          scotch;
Best regards,
Bruno
Alas not quite that simple. (t least under 2.3 with tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater).. you need to do this for each decomposeParDict for each region as well as the top level . i.e. system/[region]/decomposeParDict and system/decomposeParDict
derekm is offline   Reply With Quote
Old   October 12, 2017, 17:01
Miguel David Méndez Bohórquez
Miguel.Mendez is on a distinguished road
Hi Alain,
Best regards,
Bruno
Hi Bruno,
I hope you can help me.
I am running a Multiregion case. I have read the instructions in the Allrun script of this tutorial. When I descomposed my case and every single processor has taken their respective part of each region, but, when I am going to release the solver appears the following problem:
Cannot find file "points" in directory "polyMesh" in times 23.6 down to constant. (23.6 is my starting time).
I have checked that every region in every processor has the repective constant folder with the respective polyMesh/points file.
I executed this line:
mpirun -np 4 my_solver -parallel 1> runlog
Does exit an special statement for running multiRegion cases?
I hope have been clear. Best regards,
Miguel.
Miguel.Mendez is offline   Reply With Quote
Old   March 20, 2019, 00:01
Default Same Error
  #20
Arpan Sircar
ArpanS is on a distinguished road
I get the same error with decomposePar for a multi-region case, did you find any solution to this problem ?
Thanks
Arpan
ArpanS is offline   Reply With Quote
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 05:34
newbie problem with cavity tutorial miki OpenFOAM Running, Solving & CFD 8 September 2, 2012 15:22
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 09:50
Solver problem in Oscillating Plate tutorial vovogoal CFX 1 November 22, 2011 09:54
Help! Compiled UDF problem 4 Wave tank tutorial Shane FLUENT 1 September 3, 2010 02:32
