July 30, 2013, 08:58 |
LES for 2D case?
X Meng
Rep Power: 13 |
Dear Foamers,
When I use LES model for a 2D case, it suggests that 'LES is not strictly applicable.....' So, it means it is not ok to use LES for 2D case? A little bit confused. |
July 30, 2013, 15:51 |
Nima Samkhaniani
Rep Power: 24 |
it can be used numerically, but when i asked an expert in turbulence it says using LES for 2D cases is non-sense as it LES using spatial filter
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
July 30, 2013, 15:57 |
Alex
Rep Power: 47 |
Two-dimensional turbulence has different physical behavior than three-dimensional turbulence.
That is why LES on a 2-dim. domain should not be used to obtain reliable results for 3-dim. flows. |
July 31, 2013, 02:58 |
X Meng
Rep Power: 13 |
Emmm, I am using a 2D case to test my own developed solver, coz 3D case is bloody time-waste, if put too many grid inside the layer Y+<30.
I mean, is it a possible way to confirm the LES model's working well? |
July 31, 2013, 05:42 |
Alex
Rep Power: 47 |
If you are comparing your results to the results from another 2D LES solver, you should be fine.
July 31, 2013, 07:59 |
Lieven
Rep Power: 22 |
Hi Xiangyin,
Both Alex and Nima are correct. You need to make a distinction between validating your implementation and validating your model. * If you purely want to validate your solver (so the numerical implementation), you can compare your results with other solvers. * However, if you want to validate it, doing a 2D LES is basically pure non-sense. Turbulence is by definition a 3D effect. As soons as you neglect this, you will probably end up with pure rubbish. Cheers, Lieven |
July 31, 2013, 09:21 |
X Meng
Rep Power: 13 |
Thank you guys! That's really what I want to know.
My plan is to make sure every step is OK before using real 3D running, otherwise it is too long to try something in setup. Thanks again! |
April 26, 2020, 04:03 |
Why 2D pitzDaily with "LES" in tutorials?
#8 | |
Ali Shayegh
Rep Power: 10 |
Why OpenFOAM contains 2D pitzDaily with LES in Code:
tutorials/incompressible/pisoFoam/LES/pitaDaily Obviously it does not need to validate implementation, on the other hand, based on your saying, it is completely rubbish! Then why? |
April 26, 2020, 08:14 |
#9 |
Herpes Free Engineer
Rep Power: 12 |
OpenFOAM tutorials are neither validation nor verification, but only a set of illustrations of the functionalities of OpenFOAM, so that users can fetch parts useful to them.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
April 26, 2020, 09:09 |
#10 |
Ali Shayegh
Rep Power: 10 |
By the way, I don't think they put a wrong case just for illustration purposes; Existing a 2D LES case somehow depicts the allowability of using LES with 2D geometries, at least in some situations.
April 26, 2020, 10:13 |
#11 |
Rep Power: 12 |
turbulence is by definition a three-dimensional phenomenon, except for some simplified cases of atmospheric flows; therefore, 2D LES is almost always nonsense since any vortex stretching mechanism is theoretically nonexistent in the governing equations (note: I do not refer to statistically independency or homogeneity). accordingly, they have definitely put the tutorial as an illustration, in my opinion.
April 26, 2020, 11:19 |
#12 |
Rep Power: 6 |
Hi
Your guids and helps are so good, I use them Thank you very much. |
Transient case running with a super computer | microfin | FLUENT | 0 | March 31, 2009 11:20 |
How many BC do I need for a single LES case | wuwen | OpenFOAM Running, Solving & CFD | 0 | November 17, 2008 07:58 |
Help! Should I use LES in this case. Thanks. | Feng | FLUENT | 4 | April 25, 2008 17:04 |
Differences between a laminar code and a les one | ben | Main CFD Forum | 9 | February 16, 2005 23:40 |
Body force - Does it work? | Jan Rusås | CFX | 5 | August 27, 2002 09:50 |
