Conductive Heat Transfer in OpenFoam??
Old   May 11, 2020, 07:39
Default Conductive Heat Transfer in OpenFoam??
weizhixiong
gichiyuwu is on a distinguished road
Hi everyone, i am new to OpenFoam and Linux, and i have a quick question: Is there a way to calculate conductive heat transfer from a fluid to a solid, for example :Using water film to cool the high temperature wall, I just want to know the temperature-field of the solid part ... Thanks a lot, Flo
gichiyuwu is offline   Reply With Quote
Old   May 11, 2020, 18:54
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
- Is there any chance for you to reduce the scope of your question, if possible? In my humble opinion, the questions are a bit broad, hence less people would be able to help you.
All the best.
HPE is offline   Reply With Quote
Old   May 12, 2020, 08:34
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
quick answer to a quick question:
  • Yes you can calculate heat-transfer from fluid to solid
  • Yes you can also use film models for that; but I never investigated into that topic but in the Foundation repository, the improved a lot in this regard
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   May 12, 2020, 08:44
weizhixiong
Thank you very much for your reply, by the way, which solver is suitable for this situation
Old   May 12, 2020, 08:45
weizhixiong
Originally Posted by Tobi View Post
Hi all,
Old   May 12, 2020, 08:48
weizhixiong
Originally Posted by HPE View Post
All the best.
Thank you very much for your reply, such as cooling a small high-temperature wall with a water film, I want to know the temperature field of the wall, what solver should be suitable for this case
problem in transient heat transfer of ground heat exchanger teguhtf FLUENT 0 April 23, 2020 05:46
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Radiation interface hinca CFX 15 January 26, 2014 17:11
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 04:07
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
