"could not open file..." during compilation of dbns |
October 18, 2019, 03:26 |
Bidesh Sengupta
Rep Power: 7 |
Hi Foamers!
I am trying to write my own solver for my project. During the compilation I am receiving errors of "could not open file...". I am attached the image of compilation and "files" from Make directory. If any one can suggest me what mistake I am making, I shall be really helped. Thank you! Have a nice weekend. Bidesh |
June 26, 2020, 06:21 |
Rep Power: 8 |
does the error pop up when the compiler tries to read anything from your modified solver directory?
it may be that your compiler does not have access to it and its just a compiler issue. please open a terminal bash at your modified solver, then execute this command: chmod -R 777 "yourSolverDirectoryName" then try to compile again. |
June 26, 2020, 08:36 |
Chaewoong Ban
Rep Power: 12 |
why dont you check your Make/options, which have to include all the related header file.
I think you may omit path of some header file (makeBasicNumericIceFlux.H) |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
