Adding energy/Temprature equation to viscoelasticFluidFoam solver
Like Tree1Likes
  • 1 Post By rtyme06
Old   December 7, 2020, 10:19
Default Adding energy/Temprature equation to viscoelasticFluidFoam solver
idrees khan
idrees khan is on a distinguished road
Dear foamer's
I'm trying to add the Temperature equation(screenshort of the eqaution from the paper is attached) to viscoelastiFluidFoam solver
when i add and compile it with "wmake' I'm getting errors(screenshort is attached).
please note that here solvent viscosity (etaS) polymeric viscosity (etaP) and relaxation time Lambda depinding upon temperature.
humble request kindly guide me.
regards
Idrees
idrees khan is offline   Reply With Quote
Old   December 10, 2020, 18:52
raihan
rtyme06 is on a distinguished road
It's complaining about a mismatched type and coming from viscoelasticFluidFoam.C line 35. Can you share what that line is?
idrees khan likes this.
rtyme06 is offline   Reply With Quote
Old   December 11, 2020, 01:59
idrees khan
Dear raihan
Actually i add temp equation to a file name Teqn.H and add it to viscoelasticFluidFoam.C on line 35
so my equation of temp is
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi,T)
- fvm::laplacian(DT,T)
- 1.0/rho/Cv * (gamma*visco.tau() && Foam::symm(fvc::grad(U))+ Foam::exp( -C11*(T - To) / (C21 + T - To) )*etaS* Foam::fvc::symm(grad(U))&& Foam::fvc::grad(U))
TEqn.relax();
TEqn.solve();
this is what given in the paper (screenshort is attached in previous msg).
there is also some other term which i've to add later.but I'm adding terms step by step.
regards
idrees
Old   December 11, 2020, 16:46
raihan
Based on your error log and the equation, here is my advice for you. Simplify the temperature equation. Create new variables for the double dot product terms and use those variables in the equation. This way you know exactly which term is causing the problem.
Old   December 12, 2020, 04:00
idrees khan
Dear raihan.
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi,T)
- 1.0/rho/Cv * (gamma*visco.tau() && Foam::symm(fvc::grad(U))+ (Foam::exp( -C11*(T - To) / (C21 + T - To) )*etaS*Foam::symm(fvc::grad(U)))&& Foam:fvc::grad(U)))
TEqn.relax();
TEqn.solve();
when i add and compile with "wmake" getting the same error's
after this i removed the term "&& Foam:fvc::grad(U)))" and compile with wmake it work.
i don't know why
Foam::symm(fvc::grad(U)) is scalar it should be tensor which is basically causing error.
regards
idrees
Old   December 12, 2020, 17:46
raihan
I checked the symm() function. Looks like it returns volSymmTensorField rather than volTensorField. So that may be your problem.
//- Return the symmetric part of a tensor
template<class Cmpt>
inline SymmTensor<Cmpt> symm(const Tensor<Cmpt>& t)
return SymmTensor<Cmpt>
t.xx(), 0.5*(t.xy() + t.yx()), 0.5*(t.xz() + t.zx()),
t.yy(), 0.5*(t.yz() + t.zy()),
t.zz()
I guess the possible solution would be to simplify the steps, use additional variables, as I said before.
symm(), viscoelasticfluidfoam
Adding diffusion term to interFoam transport equation Gearb0x OpenFOAM Programming & Development 3 February 14, 2023 04:16
multiRegionHeater error ordinary OpenFOAM Running, Solving & CFD 2 June 9, 2020 17:43
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation mykkujinu2201 Main CFD Forum 1 August 12, 2017 13:15
Poisson equation in custom solver diverges for large boundary values babakflame OpenFOAM Running, Solving & CFD 2 May 23, 2017 20:11
