June 28, 2020, 21:55 |
OpenFOAM interFOAM stops without error
Collin
Rep Power: 5 |
Hello everyone,
This is my first post, so I feel obliged to say this is a neat community to find on my recently-discovered CFD journey! As the title says, OpenFOAM stops suddenly, and didn't do so until recently. I have tried modifying the controlDict, ensuring the blockMesh is okay, uncommenting the inlet to make sure that wasn't causing it, and "playing" with the values of coefficients. I would like to add that I had to use "writeNow" to stop a very long simulation at one point, and I believe I had that problem since then. I have began running in parallel thinking that maybe it would lower the load on my computer. (Even if there's plenty of space left in the hard drive.) One thing I would like to try but don't know how is how to clear workspace memory. I have also heard of this being an issue with Ubuntu, so if all else fails, I will have to find a different solution for that. (OpenFOAM v1912 and Ubuntu 18.04 is what I'm using.) There are a few threads that have responses, but none have helped me solve this or are different in nature. My next step is to re-do everything and troubleshoot it that way, but if someone could see an error that I wouldn't, I would appreciate it. I am modifying the damBreak multiphase interFoam tutorial case. The goal is to observe fluid flow over a barrier. I have a field of water on both sides, and will have an inlet sitting above the water surface to replicate a storm surge. (Using GroovyBC eventually, but first I want to start with a simple inlet to begin.) I will attach a picture below. blockMesh executes okay, and the file is copied here: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 1; vertices ( (0 0 0) (0 40 15) (0 0 15) (0 0 12) (0 40 12) (48 40 15) (48 0 15) (48 0 12) (48 40 12) (0 0 11) (0 40 11) (48 40 11) (48 0 11) (0 40 8) (0 0 8) (48 0 8) (48 40 8) (0 40 5) (0 0 5) (45 0 5) (45 40 5) (0 40 0) (0 0 0) (40 0 0) (40 40 0) (49.5 40 15) (49.5 0 15) (49.5 0 12) (49.5 40 12) (49.5 0 11) (49.5 40 11) (49.5 0 8) (49.5 40 8) (50.5 0 15) (50.5 40 15) (50.5 0 12) (50.5 40 12) (49.5 0 11) (50.5 0 11) (49.5 40 11) (50.5 40 11) (52 0 15) (52 40 15) (52 0 12) (52 40 12) (52 0 11) (52 40 11) (50.5 0 8) (50.5 40 8) (52 0 8) (52 40 8) (100 0 15) (100 40 15) (100 0 12) (100 40 12) (100 0 11) (100 40 11) (100 0 8) (100 40 8) (55 0 5) (55 40 5) (100 40 5) (100 0 5) (60 40 0) (60 0 0) (100 40 0) (100 0 0) ); blocks ( hex (1 5 6 2 4 8 7 3) (15 15 15) simpleGrading (1 1 1) hex (3 4 8 7 9 10 11 12) (15 15 15) simpleGrading (1 1 1) hex (9 10 11 12 14 13 16 15) (15 15 15) simpleGrading (1 1 1) hex (14 13 16 15 18 17 20 19) (15 15 15) simpleGrading (1 1 1) hex (18 17 20 19 22 21 24 23) (15 15 15) simpleGrading (1 1 1) hex (6 5 25 26 7 8 28 27) (15 15 15) simpleGrading (1 1 1) hex (7 8 28 27 12 11 30 29) (15 15 15) simpleGrading (1 1 1) hex (12 11 30 29 15 16 32 31) (15 15 15) simpleGrading (1 1 1) hex (26 25 34 33 27 28 36 35) (15 15 15) simpleGrading (1 1 1) hex (27 28 36 35 29 30 40 38) (15 15 15) simpleGrading (1 1 1) hex (33 34 42 41 35 36 44 43) (15 15 15) simpleGrading (1 1 1) hex (35 36 44 43 38 40 46 45) (15 15 15) simpleGrading (1 1 1) hex (38 40 46 45 47 48 50 49) (15 15 15) simpleGrading (1 1 1) hex (41 42 52 51 43 44 54 53) (15 15 15) simpleGrading (1 1 1) hex (43 44 54 53 45 46 56 55) (15 15 15) simpleGrading (1 1 1) hex (45 46 56 55 49 50 58 57) (15 15 15) simpleGrading (1 1 1) hex (49 50 58 57 59 60 61 62) (15 15 15) simpleGrading (1 1 1) hex (59 60 61 62 64 63 65 66) (15 15 15) simpleGrading (1 1 1) ); edges ( ); boundary ( BottomWalls { type wall; faces ( (22 21 24 23) (15 16 20 19) (19 20 24 23) (15 16 32 31) (29 30 32 31) (29 30 40 38) (38 40 48 47) (47 48 50 49) (49 50 60 59) (59 60 63 64) (64 63 65 66) ); } SideWalls { type wall; faces ( (1 2 3 4) (4 3 9 10) (10 9 14 13) (14 13 17 18) (18 17 21 22) (51 52 53 54) (62 61 66 65) (1 5 8 4) (2 6 7 3) (8 4 10 11) (3 7 12 9) (11 10 13 16) (9 12 15 14) (16 13 17 20) (14 15 19 18) (20 17 21 24) (18 19 23 22) (25 5 8 28) (6 26 27 7) (28 8 11 30) (7 27 29 12) (30 11 16 32) (12 29 31 15) (34 25 28 36) (26 33 35 27) (36 28 30 40) (27 35 38 29) (34 42 44 36) (33 41 43 35) (36 44 46 40) (35 43 45 38) (40 46 50 48) (38 45 49 47) (42 52 54 44) (41 51 53 43) (44 54 56 46) (43 53 55 45) (46 56 58 50) (45 55 57 49) (50 58 61 60) (49 57 62 59) (60 61 65 63) (59 62 66 64) (55 56 58 57) (53 54 56 55) ); } inlet { type patch; faces ( (57 58 61 62) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // setFields executes okay, and the text is like so: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha.water 0 ); regions ( boxToCell { box (0 0 0) (100 40 5); fieldValues ( volScalarFieldValue alpha.water 1 ); } ); // ************************************************** *********************** // Some other text files that I should add are the following: alpha.water /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { SideWalls { type zeroGradient; } BottomWalls { type zeroGradient; } inlet { type inletOutlet; inletValue uniform 1; value uniform 1; } } // ************************************************** *********************** // Velocity /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { atmosphere { type zeroGradient; } inlet { type fixedValue; value uniform (-0.1 0 0); type zeroGradient; } BottomWalls { type fixedValue; value uniform (0 0 0); } SideWalls { type fixedValue; value uniform (0 0 0); } defaultFaces { type empty; } } // ************************************************** *********************** // Pressure /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { BottomWalls { type zeroGradient; } SideWalls { type zeroGradient; } atmosphere { type fixedValue; value uniform 0; } inlet { type zeroGradient; } defaultFaces { type empty; } } // ************************************************** *********************** // Here are the results of running the simulation. I had to place a break to observe the line limit. (Not in parallel to save some work...) /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _f3950763fe-20191219 OPENFOAM=1912 Arch : "LSB;label=32;scalar=64" Exec : interFoam Date : Jun 28 2020 Time : 21:37:07 Host : Scyther PID : 1828 I/O : uncollated Case : /home/clester/OpenFOAM/OpenFOAM-v1912/tutorials/multiphase/interFoam/laminar/damBreakExperimentalNewOrleansBuild nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh staticFvMesh PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Selecting laminar stress model Stokes Reading g Reading hRef Calculating field g.h No MRF models present No finite volume options present -Break- PIMPLE: iteration 1 MULES: Solving for alpha.water Phase-1 volume fraction = 0.303237 Min(alpha.water) = -0.200123 Max(alpha.water) = 1 GAMG: Solving for p_rgh, Initial residual = 0.470101, Final residual = 0.00470078, No Iterations 142 GAMG: Solving for p_rgh, Initial residual = 0.0312548, Final residual = 0.00030107, No Iterations 14 GAMG: Solving for p_rgh, Initial residual = 0.00764932, Final residual = 7.15317e-05, No Iterations 16 GAMG: Solving for p_rgh, Initial residual = 0.00169319, Final residual = 1.66293e-05, No Iterations 14 GAMG: Solving for p_rgh, Initial residual = 0.00078458, Final residual = 7.3817e-06, No Iterations 26 GAMG: Solving for p_rgh, Initial residual = 0.000337959, Final residual = 1.94399e-06, No Iterations 9 time step continuity errors : sum local = 1.11299e-06, global = 1.09047e-06, cumulative = 0.0011982 GAMG: Solving for p_rgh, Initial residual = 0.0073358, Final residual = 4.95642e-05, No Iterations 7 GAMG: Solving for p_rgh, Initial residual = 0.00193711, Final residual = 1.78786e-05, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.000341676, Final residual = 2.78262e-06, No Iterations 210 GAMG: Solving for p_rgh, Initial residual = 0.000127011, Final residual = 1.14741e-06, No Iterations 6 GAMG: Solving for p_rgh, Initial residual = 0.000103713, Final residual = 9.20448e-07, No Iterations 15 GAMG: Solving for p_rgh, Initial residual = 9.78167e-05, Final residual = 8.19684e-07, No Iterations 2 time step continuity errors : sum local = 1.10003e-06, global = 1.09047e-06, cumulative = 0.00119929 GAMG: Solving for p_rgh, Initial residual = 0.00298343, Final residual = 1.80917e-05, No Iterations 41 GAMG: Solving for p_rgh, Initial residual = 0.00125604, Final residual = 1.0222e-05, No Iterations 8 GAMG: Solving for p_rgh, Initial residual = 0.000227536, Final residual = 2.04574e-06, No Iterations 219 GAMG: Solving for p_rgh, Initial residual = 0.000110576, Final residual = 1.0941e-06, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 9.8762e-05, Final residual = 9.23246e-07, No Iterations 17 GAMG: Solving for p_rgh, Initial residual = 9.625e-05, Final residual = 9.64234e-09, No Iterations 47 time step continuity errors : sum local = 1.09058e-06, global = 1.09047e-06, cumulative = 0.00120038 ExecutionTime = 30.98 s ClockTime = 31 s Courant Number mean: 0.0049064 max: 0.465085 Interface Courant Number mean: 0.000231217 max: 0.441517 deltaT = 0.000471213 Time = 0.111412 PIMPLE: iteration 1 MULES: Solving for alpha.water Phase-1 volume fraction = 0.303078 Min(alpha.water) = -0.158106 Max(alpha.water) = 1 GAMG: Solving for p_rgh, Initial residual = 0.170063, Final residual = 0.00156235, No Iterations 6 GAMG: Solving for p_rgh, Initial residual = 0.142723, Final residual = 0.00125877, No Iterations 3 GAMG: Solving for p_rgh, Initial residual = 0.022829, Final residual = 0.000214916, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 0.00845082, Final residual = 7.71115e-05, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.00162058, Final residual = 1.54251e-05, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.000624829, Final residual = 5.19422e-06, No Iterations 5 time step continuity errors : sum local = 1.80142e-07, global = -1.42733e-07, cumulative = 0.00120024 GAMG: Solving for p_rgh, Initial residual = 0.0168994, Final residual = 0.000152438, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 0.0288547, Final residual = 0.000258572, No Iterations 3 GAMG: Solving for p_rgh, Initial residual = 0.00645428, Final residual = 3.41505e-05, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.00155527, Final residual = 1.443e-05, No Iterations 3 GAMG: Solving for p_rgh, Initial residual = 0.00027886, Final residual = 2.05474e-06, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 8.59067e-05, Final residual = 6.97358e-07, No Iterations 4 time step continuity errors : sum local = 1.48048e-07, global = -1.42733e-07, cumulative = 0.0012001 GAMG: Solving for p_rgh, Initial residual = 0.0043278, Final residual = 3.51257e-05, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.00307099, Final residual = 1.4587e-05, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 0.00198226, Final residual = 1.49418e-05, No Iterations 3 GAMG: Solving for p_rgh, Initial residual = 0.000408654, Final residual = 2.40682e-06, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.00012201, Final residual = 5.90776e-07, No Iterations 3 GAMG: Solving for p_rgh, Initial residual = 4.19613e-05, Final residual = 9.89588e-09, No Iterations 12 time step continuity errors : sum local = 1.42809e-07, global = -1.42733e-07, cumulative = 0.00119995 ExecutionTime = 33.8 s ClockTime = 34 s Courant Number mean: 0.0126857 max: 0.640437 Interface Courant Number mean: 8.99744e-06 max: 0.0274552 deltaT = 0.000367585 Time = 0.11178 PIMPLE: iteration 1 MULES: Solving for alpha.water Phase-1 volume fraction = 0.303089 Min(alpha.water) = -0.173888 Max(alpha.water) = 1 And if I run it again from where it left off, it stops at about the same time. (Could be a potential hint?) Are there any ideas as to why this is happening or suggestions for finding a way through this? Thank you for any help or suggestions! Collin |
June 28, 2020, 21:56 |
Adding the controlDict
Collin
Rep Power: 5 |
| ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application interFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 1; deltaT 0.1; writeControl adjustable; writeInterval 0.1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.5; maxAlphaCo 0.5; maxDeltaT 1; libs ( "libOpenFOAM.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" "libgroovyBC.so" ); // ************************************************** *********************** // |
September 2, 2022, 08:11 |
daniel lai
Hey!
Have you find a solution for this problem? I'm having the same problem here using interFoam solver with dynamicMesh (rotating - AMI). Suddenly the Ubuntu interface stops printing the progress, and I guess it is because of the alpha.water number (max), which reaches the value above 32.0. |
January 7, 2024, 09:40 |
#4 | |
Volkan Atar
Rep Power: 3 |
were you able to find out why this is? I'm having exactly same problem. AMI-Mesh with interFoam. moveDynamicMesh -checkAMI looks really fine befor the simulation. As i execute interFoam it directly stops without any error message :/ |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
