With changing the origin of my geometry, I'm not getting the same Results |
September 4, 2020, 10:59 |
Muhammad Kashif Jawad
Rep Power: 5 |
Hi All,
I'm working on this project for months. I'm using Multi-phase, InterFoam, WaterChannel case. Openfoam Version 5.0 My problem is that in the beginning, my origin in the blockmeshDict was left corner of Branch Channel & when i got my solution converged, I changed the origin in the blockMeshDict according to the paper i was following. But with changing this origin I'm not getting the same results at outlet as i got with the first blockMeshDict file. All my other files are same. My files are attached below with more description. InkedFirstCase_LI.jpg This is my first case as you can see here, the value near the outlet and my origin shown with arrow. Inked2ndCase_LI.jpg This is my 2nd case, Remember that I'm using same BC's , Nothing changed except this origin. Similarly Velocity also varies. blockmeshDict files.zip Here are my Both blockMeshDict files. I was looking for this problem on this forum & as well as i googled but i couldn't find the answer. I'm looking for someone who can help me in this regard or atleast give me some suggestions. Any help would be deeply appreciated. Thanks Regards. |
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so | immortality | OpenFOAM Pre-Processing | 15 | April 7, 2024 12:35 |
[ANSYS Meshing] 2D mesh from a 3D geometry results in 1m thick mesh | herrolsen | ANSYS Meshing & Geometry | 2 | March 26, 2019 15:00 |
Can i get results of 800m*600m*100m box geometry? | pcbaliwal | FLUENT | 2 | April 3, 2017 00:33 |
[snappyHexMesh] different sHM results on same geometry when everythin is in one or several stl-files. | Laika | OpenFOAM Meshing & Mesh Conversion | 1 | September 8, 2016 04:09 |
Equation for a rotating circle outside the origin | mali28 | Main CFD Forum | 0 | November 14, 2014 06:38 |
