openmpi on windows server with two additional virtual machines |
August 10, 2021, 04:46 |
Rep Power: 8 |
hi all,
i have a windows server with two additional virtual machines on it. i am using the server with two other co-workers. when i start a simulation with the virtual machines, the used cores are not fixed, they change the whole time, i attached two screenshots for two different times. the problem is, when i use nearly all cores, because the simulations do not use the same cores, it slows down the computation time. i think thats because when the cores are switched, the simulation waits until it can use the core, which will be free when calculation is done there. i already used mpirun options like --bind-to core or --bind-to socket and -cpu-set but no success so far. i hope anybody can help in this regard. |
mpirun, openmpi, parallel |
OpenFOAM for Windows 10 | cfd.direct | OpenFOAM Announcements from OpenFOAM Foundation | 6 | April 22, 2020 07:08 |
Openfoam on windows cluster with OpenMPI | craig.tickle | OpenFOAM Installation | 9 | October 16, 2014 23:21 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
