Setting internal flow Boundary Conditions on OpenFOAM |
November 24, 2020, 09:40 |
Matheus
Rep Power: 6 |
Hi there OpenFOAM community, I would appreciate a lot if any of you could help me out, I'm using snappyHexMesh to generate a tube in order to run an internal, incompressible, turbulent flow. I'm using as a base for the code the motorcycle tutorial, but it's originally external flow, I've tried tinkering the boundary conditions for the variables inside the 0 folder but setting the tube as a fixedwall still made the the flow run over it instead of inside. Do i need to import only the "shell" of the tube without both surfaces that covers it? Thanks in advance!
November 24, 2020, 21:56 |
Rep Power: 5 |
Hi Matheus,
Are you sure that you are setting 'locationInMesh' keyword in 'castellatedMeshControls' correctly to choose the inside of the tube as your flow domain? Cheers |
boundary condition, internal flow, openfoam |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
