Flow pass 2D square cylinder using LES-channel 395 question |
May 30, 2016, 18:46 |
Bashar
Rep Power: 10 |
Dear All,
I am currently working on simulation for 2D square cylinder with Re=50000. I am trying to use LES with WALE SGS. I used the setup in the case "channel 395" in tutorial to build my own case, unfortunately I have been using openFoam for 3 months only, so I have a question regarding the data in the "0" folder inside this case: are they related to the WALE model? i.e can I use different setup for the variables inside this folder like ( P,U,K,B,..etc) from another model like Smagorinsky? the reason for that is related to the nature of this tutorial,"channel 395", for example the variable "k" is filled with data like shown below: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: splitCyclic | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 2 -2 0 0 0 0 ]; internalField nonuniform List<scalar> 60000 ( 0.000546979 0.000539726 0.000522268 0.000486501 0.00042352 0.000340779 0.000261349 0.000205418 0.000176593 0.000165225 0.000161396 0.00016139 0.000166469 0.000177507 0.000193931 0.000215604 0.000243705 0.000278988 ..... 5.34299e-05 5.57113e-05 5.80269e-05 6.14485e-05 6.61096e-05 7.18528e-05 7.79562e-05 8.41191e-05 ) ; boundaryField { bottomWall { type fixedValue; value uniform 0; } topWall { type fixedValue; value uniform 0; } sides1_half0 { type cyclic; } sides2_half0 { type cyclic; } inout1_half0 { type cyclic; } inout2_half0 { type cyclic; } sides2_half1 { type cyclic; } sides1_half1 { type cyclic; } inout1_half1 { type cyclic; } inout2_half1 { type cyclic; } } // ************************************************** *********************** // Which I could not understand how to use my data in this file . and I saw that other LES tutorial is much easier to work with it when it come to the variables inside the "0" folder. So sorry for this long questions , I hope some one have any advice. Regards, Bashar |
January 8, 2021, 01:53 |
Rep Power: 9 |
Hi Bashar,
I am facing the same thing. How you resolved this issue? did you get the idea for obtaining these non-uniform internal fields? |
Flow past a 2D cylinder - High Re (1E+05) - Cd too high | Pervispasco | OpenFOAM Running, Solving & CFD | 4 | March 14, 2022 02:19 |
Applyinga one phase LES to rectangular channel flow | roi247 | FLUENT | 5 | January 30, 2020 14:59 |
LES: Turbulent Channel Flow without initial solution (BC) | DaSh | OpenFOAM Running, Solving & CFD | 21 | February 8, 2015 16:09 |
LES of a turbulent channel flow stays laminar | liu | OpenFOAM Running, Solving & CFD | 2 | May 27, 2010 13:53 |
Slug flow in square channel | PaulC | FLUENT | 0 | December 5, 2005 02:03 |
