February 13, 2021, 11:27 |
Add source term in the NS equation
Thibaut
Rep Power: 5 |
I built a polynomial solution for the compressible NS equations, which gives me a source term which is also polynomial. In every paper I read about OpenFoam solvers, I see no source term. However when I look in the source code of rhoPimpleFoam, I can see a ==fvOptions(U). I guess this is the source term. I tried this in fvOptions: Code:
vectorCodedSource { type vectorCodedSource; name vectorCodedSource; selectionMode all; fields (U); codeInclude #{ #}; codeCorrect #{ Pout<< "**codeCorrect**" << endl; #}; codeAddSup #{ const Time& time = mesh().time(); const scalarField& V = mesh_.V(); vectorField& uSource = Uqn.source(); // Retrieve the x component of the cell centres const scalarField& cellx = mesh_.C().component(0); forAll(cellx,i) { uSource[i] += (1e5*(5-cellx[i]),0,0); } #}; codeConstrain #{ Pout<< "**codeConstrain**" << endl; #}; } Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 3 corrector loops Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type laminar Selecting laminar stress model Stokes Creating field dpdt Creating field kinetic energy K No MRF models present Creating finite volume options from "system/fvOptions" Selecting finite volume options type vectorCodedSource Source: vectorCodedSource - selecting all cells - selected 100 cell(s) with volume 40 Courant Number mean: 0 max: 0 Starting time loop Courant Number mean: 0 max: 0 deltaT = 1.20048e-06 Time = 1.20048e-06 PIMPLE: iteration 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 Using dynamicCode for fvOption::vectorCodedSource at line 19 in "/mnt/c/Users/MyName/OpenFOAM/shockTubeSource/system/fvOptions.vectorCodedSource" Could not load "/mnt/c/Users/MyName/OpenFOAM/shockTubeSource/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libvectorCodedSource_f246261c7f08eb1177877a95da075ee833702145.so" /mnt/c/Users/MyName/OpenFOAM/shockTubeSource/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libvectorCodedSource_f246261c7f08eb1177877a95da075ee833702145.so: cannot open shared object file: No such file or directory Invoking wmake libso /mnt/c/Users/MyName/OpenFOAM/shockTubeSource/dynamicCode/vectorCodedSource wmake libso /mnt/c/Users/MyName/OpenFOAM/shockTubeSource/dynamicCode/vectorCodedSource Could not load "/mnt/c/Users/MyName/OpenFOAM/shockTubeSource/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libvectorCodedSource_f246261c7f08eb1177877a95da075ee833702145.so" /mnt/c/Users/MyName/OpenFOAM/shockTubeSource/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libvectorCodedSource_f246261c7f08eb1177877a95da075ee833702145.so: cannot open shared object file: No such file or directory Selecting finite volume options type vectorCodedSource Source: vectorCodedSource - selecting all cells - selected 100 cell(s) with volume 40 Using dynamicCode for fvOption::vectorCodedSource at line 0 in "/mnt/c/Users/MyName/OpenFOAM/shockTubeSource/system/fvOptions.vectorCodedSource" Could not load "/mnt/c/Users/MyName/OpenFOAM/shockTubeSource/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libvectorCodedSource_f246261c7f08eb1177877a95da075ee833702145.so" /mnt/c/Users/MyName/OpenFOAM/shockTubeSource/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libvectorCodedSource_f246261c7f08eb1177877a95da075ee833702145.so: cannot open shared object file: No such file or directory Invoking wmake libso /mnt/c/Users/MyName/OpenFOAM/shockTubeSource/dynamicCode/vectorCodedSource wmake libso /mnt/c/Users/MyName/OpenFOAM/shockTubeSource/dynamicCode/vectorCodedSource Could not load "/mnt/c/Users/MyName/OpenFOAM/shockTubeSource/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libvectorCodedSource_f246261c7f08eb1177877a95da075ee833702145.so" /mnt/c/Users/MyName/OpenFOAM/shockTubeSource/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libvectorCodedSource_f246261c7f08eb1177877a95da075ee833702145.so: cannot open shared object file: No such file or directory Selecting finite volume options type vectorCodedSource Last edited by Taendyr; February 15, 2021 at 07:58. |
Source Term due to evaporation in energy transport equation | styleworker | OpenFOAM Programming & Development | 3 | September 7, 2022 03:09 |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
