March 26, 2021, 13:39 |
Pressure driven flow
Rep Power: 5 |
Hello everybody,
I am trying to do a pressure derived flow in a quenching chamber working at 5 bars. With the following geometry. case.jpg The tubes are the inlets and the blue circle at the back is the outlet. Obviously I want to have a flow perpendicular to the inlet patches . To assure this I wrote the boundary conditions for the velocity : pressureNormalInletOutletVelocity. But how come my results of the velocity field are all parallel to the X axis ? vectors.jpg And how the U magnitude is not the same for the bottom inlets ? This might be because I am imposing p_rgh ( so there is some gravitational effect that enters. But then how can I impose a same inlet velocity for all the inlets with a pressure driven flow? ( I am using chtMultiRegionFoam, I don't know if it is important to mention ) Does any body know how to get the flow I want to have. That is a flow coming from the inlet patches ( perpendicularly ) and a flow leaving the chamber through the outlet. With a pressure driven flow. Here are my boundary conditions are the following for p_rgh and U: p_rgh Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0/vaccum"; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 1 -1 -2 0 0 0 0 ]; internalField uniform 500000; boundaryField { outlet { type prghTotalPressure; value uniform 499900; p0 uniform 499900; } walls { type fixedFluxPressure; value $internalField; } inletN { type prghTotalPressure; value uniform 500050; p0 uniform 500050; } inletNE { type prghTotalPressure; value uniform 500050; p0 uniform 500050; } inletSE { type prghTotalPressure; value uniform 500050; p0 uniform 500050; } inletS { type prghTotalPressure; value uniform 500050; p0 uniform 500050; } inletSW { type prghTotalPressure; value uniform 500050; p0 uniform 500050; } inletNW { type prghTotalPressure; value uniform 500050; p0 uniform 500050; } vaccum_to_block { type fixedFluxPressure; value $internalField; } } // ************************************************************************* // U Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0/vaccum"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 1 -1 0 0 0 0 ]; internalField uniform ( 0 0 0 ); boundaryField { outlet { type pressureNormalInletOutletVelocity; value uniform ( 0 0 0 ); } walls { type noSlip; value uniform ( 0.01 0 0 ); } inletN { type pressureNormalInletOutletVelocity; value uniform ( 0 0 0 ); } inletNE { type pressureNormalInletOutletVelocity; value uniform ( 0 0 0 ); } inletSE { type pressureNormalInletOutletVelocity; value uniform ( 0 0 0 ); } inletS { type pressureNormalInletOutletVelocity; value uniform ( 0 0 0 ); } inletSW { type pressureNormalInletOutletVelocity; value uniform ( 0 0 0 ); } inletNW { type pressureNormalInletOutletVelocity; value uniform ( 0 0 0 ); } vaccum_to_block { type noSlip; value uniform ( 0 0 0 ); } } // ************************************************************************* // |
March 26, 2021, 15:03 |
Rep Power: 5 |
Problem solved normally!
Pressure driven flow with rhoSimpleFoam Error | OpenFOOL | OpenFOAM Running, Solving & CFD | 2 | February 22, 2023 11:41 |
Pressure driven compressible flow between two gas reservoirs | dld | OpenFOAM Running, Solving & CFD | 1 | October 27, 2022 14:45 |
Simple Box - Gravity with Pressure Outlet - Unrealistic Reverse Flow | pyccknn | FLUENT | 2 | December 1, 2021 17:31 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
