Error while installing sedfoam
Like Tree1Likes
  • 1 Post By sourav8016
Old   April 29, 2021, 08:49
Default Error while installing sedfoam
Sourav Hossain
sourav8016 is on a distinguished road
Dear Foamers,
I have been trying to install sedfoam. I am using openfoam6 in ubuntu 16.04. While running ./Allwmake command, I get the following errors
Foam::sedIncompressibleTurbulenceModel<TransportMo del>:Primef() const’:
../TurbulenceModels/turbulenceModels/lnInclude/sedIncompressibleTurbulenceModel.C:128:12: error: ‘New’ is not a member of ‘Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >’
return tmp<surfaceScalarField>::New
/home/sourav/OpenFOAM/OpenFOAM-6/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt64Opt/sedFoam_MULES.o' failed
make: *** [Make/linux64GccDPInt64Opt/sedFoam_MULES.o] Error 1
Please help me out. Thanks in advance.
thiago vieira likes this.
sourav8016 is offline   Reply With Quote
Old   May 2, 2021, 19:46
Thiago Vieira de Souza
thiago vieira is on a distinguished road
Dear Sourav and community,
I've been trying to install sedFoam myself, but encountered the exact same mistake you did.
On a ubuntu 18.04 OS, I've tried installing sedfoam with OpenFOAM v2.4, v5 and v6, without any success. Every time I run ./Allwmake I get that same error output of yours.
In case you, or anyone else, found the solution to this problem, I would very much appreciate if you shared it.
Regards
thiago vieira is offline   Reply With Quote
Old   May 3, 2021, 08:46
Sourav Hossain
Regards
sedfoam is now supporting the OpenFOAM versions of OpenFoam.com only.
OpenFoam v2012 is compatible with sedfoam. Unfortunately I have not installed sedfoam yet. Still If I could help, please let me know.
Thanks.
Old   May 3, 2021, 11:30
Thanks for replying!
I'm still struggling with sedFoam installation. I know that the toolbox was developed for OpenFOAM 2.4, but I've already unsuccessfully tried using it. What's more, in the comments written in the file sedFoam.C it says that it should "run automatically with openFOAM 6". Again, no success with this version of OF.
I'll keep trying and keep you posted in case I make any progress.
Old   May 5, 2021, 21:38
Greetings, community
I was able to successfully install and build sedFoam-2.0
I'm using a ubuntu 20.04 operational system with OpenFOAM-v2012 installed in it, along with the packages swak4Foam and fluidfoam.
Old   June 5, 2021, 05:38
Default Error while hitting paraFoam command in OpenFOAMv2012
Sourav Hossain
I just have installed OPENFOAMv2012 in my ubnuntu 20.04 operating system. I have done it using the steps followed by the following website :
https://www.cemf.ir/how-to-install-o...ack-on-ubuntu/
Installation was done successfully. But while running tutorial, after hitting paraFoam command in terminal, It shows
Invalid $PV_PLUGIN_PATH and -plugin-path= not defined
No supplementary ParaView/OpenFOAM reader modules
Using builtin reader: paraFoam -vtk
Created temporary 'pitzDaily.foam'
/home/souravhossain/OpenFOAM/OpenFOAM-v2012/bin/paraFoam: 420: paraview: not found
I was not able to figure it out. Please help me out.
Thanks in advance.
Old   June 6, 2021, 21:42
Dear Sourav,
The problem you are facing has nothing to do with the sedFoam application, it's related to the installation process of OpenFoam-v2012.
Try installing according to the instructions given on the OpenFoam official website
i.e. https://www.openfoam.com/
If that doesn't work, try downloading ParaView separately from OpenFoam.
https://www.paraview.org/
Hope you can figure it out.
Regards
Old   January 4, 2022, 02:51
Default collect2: error: ld returned 1 exit status
Thokala Divya
divyathokala01@gmail.com is on a distinguished road
Hi foamers,
I was struggling to install sedfoam from github in OpenFOAM-v2012. I am getting following error can someone help me to solve it please.
Starting compile of sedFoam with OpenFOAM-v2012
Gcc63 ThirdParty compiler
linux64Gcc63DPInt32Opt, with OPENMPI openmpi-4.0.3
prefix = default (user)
+ turbulenceModels/Allwmake
+ wmake libso
wmake libso (turbulenceModels)
+ [ -f wallFunctions/Allwmake ]
+ wallFunctions/Allwmake
+ wilcoxomegawallfunction/Allwmake
+ wmake libso
wmake libso (wilcoxomegawallfunction)
+ wmake libso phaseModel
+ wmake libso interfacialModels
+ wmake libso ppModel
wmake libso ppModel
+ wmake libso kineticTheoryModels
+ wmake libso granularRheologyModels
+ wmake
g++ -std=c++11 -m64 -pthread -DOPENFOAM=2012 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -iquote. -IlnInclude -I/home/chinni/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude -I/home/chinni/OpenFOAM/OpenFOAM-v2012/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed -L/home/chinni/OpenFOAM/OpenFOAM-v2012/platforms/linux64Gcc63DPInt32Opt/lib \
-lOpenFOAM -ldl \
-lm -o OpenFOAM.out
/usr/bin/ld: /lib/x86_64-linux-gnu/crt1.o: in function `_start':
(.text+0x24): undefined reference to `main'
divyathokala01@gmail.com is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
Install OF 1.6.ext on Arch based distribution miro2000 OpenFOAM Installation 4 October 9, 2013 15:39
My experience Installing Elmer (Open Source Multi physics programme) on Linux Ahmed Main CFD Forum 3 August 10, 2010 14:42
