how to put if statement in between volScalarField and dimensionedScalar
Old   August 21, 2021, 12:46
Default how to put if statement in between volScalarField and dimensionedScalar
Sourav Hossain
sourav8016 is on a distinguished road
Hi Foamers,
I have to put a if statement in between a volScalarField and dimensionedScalar. The part of the code is :
volScalarField y = mesh.C().component(vector::Y);
volScalarField u = ustar*(((1.0-Y0)/(Y0-Foam::log(Y0)-1.0))*Foam::log(y)/(h*Y0)));
if(y >= Y0*h && y <= h )
u = ustar*(((1.0-Y0)/(Y0-Foam::log(Y0)-1.0))*Foam::log(y/(h*Y0)));
else
u = 0.0;
dimensionedScalar Y0
transportProperties.lookup("Y0")
dimensionedScalar h
transportProperties.lookup("h")
u = u_*\frac{(1-Y_0)}{Y_0-\ln{Y_0}-1}\ln{\frac{y}{hY_0}} \,\text{for}\, Y_0h\leq y \leq h
After running the code I'm getting this error :
.C:82:24: error: no match for ‘operator<=’ (operand types are ‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ and ‘Foam::dimensionedScalar {aka Foam::dimensioned<double>}’)
Last edited by sourav8016; August 21, 2021 at 12:50. Reason: previous one was incomplete
sourav8016 is offline   Reply With Quote
Old   August 23, 2021, 04:06
geth03 is on a distinguished road
Originally Posted by sourav8016 View Post
Hi Foamers,
else
u = 0.0;
dimensionedScalar h
you try to compare a value without dimensions with a value with dimensions,
so you are getting a dimension error. if you want to ignore it, which i do not recommend, you can just grab the values from both sides and compare the values. but the better way would be to fix the dimensions.
geth03 is offline   Reply With Quote
Old   August 23, 2021, 05:24
Sourav Hossain
Finally I have fixed it. Here is the code, that works well.
forAll(mesh.C(), i)
if((y[i] >= Y0.value()*h.value()) && (y[i] <= h.value()) )
u[i] = ustar.value()*(((1.0-Y0.value())/(Y0.value()-Foam::log(Y0.value())-1.0))*Foam::log(y[i]/(h.value()*Y0.value())));
else
u[i] = 0.0;
How to change a dimensionedScalar into volScalarField purnp2 OpenFOAM Programming & Development 3 May 31, 2019 16:37
changing a volScalarField to a dimensionedScalar wschosta OpenFOAM Running, Solving & CFD 5 May 6, 2015 10:20
make a dimensionedScalar to be volScalarField sharonyue OpenFOAM Programming & Development 4 April 2, 2014 05:44
dimensionedScalar + volScalarField is evaluated elementwisely ? tianyikillua OpenFOAM Programming & Development 1 March 30, 2012 03:12
Confused about how OF handles operation between volScalarField and dimensionedScalar Edy OpenFOAM 3 September 30, 2010 10:07
