[Sponsors] | |||||
mesh errors in Propellor example using checkMesh |
Provence-Alpes-Cote-d'Azur
Rep Power: 8 ![]() |
I am trying to run a modified version of the propellor example as provided in OpenFoam 8 As pimplefoam continues to fail on my modified propeller geometry I am using checkMesh trying to understand what is wrong. Code:
checkMesh -allGeometry -allTopology -writeSets vtk Why is it that the original mesh of the example has so many errors ? Isn't the example supposed to run without meshing errors ? Thanks in advance, Maarten, Code:
geometry...
Overall domain bounding box (-0.3 -0.8 -0.301741) (0.3 0.2 0.301741)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (-3.05825e-17 -4.94035e-17 3.62601e-17) OK.
Max cell openness = 3.26495e-16 OK.
Max aspect ratio = 4.8112 OK.
Minimum face area = 3.76263e-09. Maximum face area = 0.0035105. Face area magnitudes OK.
Min volume = 3.65987e-10. Max volume = 0.000170818. Total volume = 0.280506. Cell volumes OK.
Mesh non-orthogonality Max: 62.5882 average: 7.58402
Non-orthogonality check OK.
Face pyramids OK.
***Max skewness = 6.68429, 23 highly skew faces detected which may impair the quality of the results
<<Writing 23 skew faces to set skewFaces
Coupled point location match (average 0) OK.
***Error in face tets: 355 faces with low quality or negative volume decomposition tets.
<<Writing 343 faces with low quality or negative volume decomposition tets to set lowQualityTetFaces
Min/max edge length = 3.39833e-05 0.0669812 OK.
<<Writing 44946 near (closer than 1.31308e-06 apart) points to set nearPoints
*There are 876 faces with concave angles between consecutive edges. Max concave angle = 73.9559 degrees.
<<Writing 876 faces with concave angles to set concaveFaces
Face flatness (1 = flat, 0 = butterfly) : min = 0.40278 average = 0.999356
*There are 12 faces with ratio between projected and actual area < 0.8
Minimum ratio (minimum flatness, maximum warpage) = 0.40278
<<Writing 12 warped faces to set warpedFaces
Cell determinant (wellposedness) : minimum: 0.197347 average: 11.926
Cell determinant check OK.
***Concave cells (using face planes) found, number of cells: 18042
<<Writing 18042 concave cells to set concaveCells
Face interpolation weight : minimum: 0.100592 average: 0.48225
Face interpolation weight check OK.
Face volume ratio : minimum: 0.0256112 average: 0.907362
Face volume ratio check OK.
Calculating AMI weights between owner patch: AMI1 and neighbour patch: AMI2
AMI: Creating addressing and weights between 22416 source faces and 22416 target faces
AMI: Patch source sum(weights) min/max/average = 1, 1, 1
AMI: Patch target sum(weights) min/max/average = 1, 1, 1
Failed 3 mesh checks.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 06:28 |
| [mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
| Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 11:08 |
| Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
| Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
