February 11, 2022, 11:13 |
Droplet Maximum diameter and height
Shubham
Rep Power: 4 |
I am simulating droplet impingement on surface using interFoam. To validate my case with some experimental result, I need the droplet maximum diameter and thickness at different time step. Is there any postprocessing cmd/ some function which can be used while running the case to serve my purpose.
Can it be done in Paraview? |
Droplet Impact 2D Axisymmetric Simulation | fazzesco | Fluent Multiphase | 0 | February 19, 2021 09:52 |
Consideration of first cell height of prism layer for laminar flow in heat transfer | swapnil13 | FLUENT | 0 | September 9, 2019 05:30 |
[ANSYS Meshing] Consideration of first cell height of prism layer for laminar flow in heat transfer p | swapnil13 | ANSYS Meshing & Geometry | 0 | September 8, 2019 03:42 |
air dancer maximum height problem | Aleksey_at_cfd | Main CFD Forum | 20 | January 11, 2019 06:10 |
FLUENT Spreading diameter surface monitor query | EIvb | FLUENT | 1 | May 22, 2013 08:13 |
