source term that stays constant over outerCorrectors of pimple loop
Old   February 18, 2022, 23:45
Default source term that stays constant over outerCorrectors of pimple loop
Jnana Bhaskar Rao
jnanabrao is on a distinguished road
Dear all,
My transient compressible flow calculation requires addition of random disturbances to the boundary layers of a nozzle at a particular location. The way I tried to do it is
1) create a cellSet of the boundary cells at the location.
2) Add random momentum source terms (disturbances) of the necessary magnitude using fvOptions active only at the aforementioned cellSet.
The issue:
For reasons I can't elaborate here, I need to use a pimple solver with 5 outerCorrector loops. I would like to keep my source term constant over all the 5 correctors. Unfortunately, when I tried to do so, I realized that fvOptions is called each time the U.Eqn is solved and it modifies the disturbances at each outer corrector step. My code for fvOptions is shared below
codedSource
    type            vectorCodedSource;
    selectionMode   cellSet;
    cellSet         boundaryLayerForce;
    fields           (U);
    name           disturbance;
    codeInclude
    #include "Random.H"
    # include "clock.H"
    codeCorrect
    codeAddSup
        const Time& time = mesh().time();
        Random rng(time.value());//Random rng(clock::getTime() + pid());
        vectorField& USource = eqn.source();
        // Start time
        const scalar startTime = -1.0;
        if (time.value() > startTime)
             const labelList& cellIDs = cells();
            // Apply the source
            forAll(cellIDs, i)
                label cellI = cellIDs[i];
                vector epsilon (1, 1, 1);
                epsilon.x() = -1.0 + 2.0*(rng.scalar01());
                epsilon.y() = -1.0 + 2.0*(rng.scalar01());
                epsilon.z() = 2.0*(-1.0 + 2.0*(rng.scalar01()));
                USource[cellI].x() =1e-4*508*epsilon.x();
                USource[cellI].y() =1e-4*508*epsilon.y();
                USource[cellI].z() = 1e-4*508*epsilon.z();
    codeSetValue
As you can see the disturbances are scaled a fixed order of magnitude from a scalar (1e-04*508). These are then randomly weighed with a different random number between -2 and 2 in each cell.
The constant updating of the disturbances within a time step is not what I want and it leads to immediate blow up of the calculation.
My questions:
Is it possible to use fvOptions to add source terms that stay constant at a time step over all the outer correctors? It seems possible as fvOptions can access the time value.
Do I have to modify my solver in order to add disturbances and solve with a pimple loop?
Last edited by jnanabrao; February 20, 2022 at 03:33. Reason: I realized I didn't need to multiply the source term with rho. The main question is still open
jnanabrao is offline   Reply With Quote
[openSmoke] LaminarSMOKE compilation error mdhfiz OpenFOAM Community Contributions 7 October 4, 2022 13:57
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
