Boundary Conditions in OpenFOAM
Old   March 28, 2022, 09:03
Default Boundary Conditions in OpenFOAM
Paul
Paul.E is on a distinguished road
Good morning,
I'm new in this forum. I would use OpenFOAM in my thesis. I have to do a simulation about an incompressible fluid through a duct.
The outlet pressure should fall fron an intitial value to the atmospheric pressure. Therefore, I want to use a csv File where I've written all the pressure values during the simulation.I've had some problems, the simulation doesn't run, so, I'm looking for an advice.
I show the initial condition written in the 0 folder.
Regards
outlet
type fixedProfile;
profile tableFile;
profileCoeffs
nHeaderLine 1;
refColumn 1;
componentColumns 2 (0 1);
separator " ";
mergeSeparators no;
file "0/data.csv";
interpolationScheme linear;
data.csv is like this:
0.0000 5000000
0.0001 4995100
0.0002 4990200
0.0003 4985300
0.1000 100000
--> FOAM FATAL IO ERROR:
incorrect first token, expected <int> or '(', found on line 1 the doubleScalar 0
file: 0/data.csv at line 1.
Paul.E is offline   Reply With Quote
Old   March 29, 2022, 03:42
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
A table file hast to look like this
   ( 0.0000 5000000 )
   ( 0.0001 4995100 )
   ( 0.0002 4990200 )
   ( 0.0003 4985300 )
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 31, 2022, 05:04
Paul
Thanks, with the parenthesis in the data file, the simulation runs correctly.
boundary condition, incompressible fluid
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 16, 2020 23:44
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 21:16
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 11:14
