Mass fraction of species is reduced "spontaneously" in phase change solver
Old   July 20, 2016, 06:38
Default Mass fraction of species is reduced "spontaneously" in phase change solver
Michael Frank
mike.franky is on a distinguished road
I am using the reactingMultiphaseEulerfoam to simulate evaporation of water at the interface of a bubble column. The mixture has a very small mass fraction of water (3x10^-5). I am using the Arden Buck saturation model. The temperature is 15 decgrees Celsius and the liquid is at atmospheric pressure. When I start the simulation, the the liquid water mass fraction goes to negative values almost instantly in a large number of cells. On the other hand, the mass fraction of the water vapour does not increase accordingly. Therefore, I believe that this must be some issue regarding numerical accuracy. Has anyone experienced anything similar or can shed some light as to how to overcome this problem?
Thanks in advance for any help
Cheers
Mike
mike.franky is offline   Reply With Quote
Old   April 28, 2022, 14:08
Vitor Monteiro
Vitor Monteiro is on a distinguished road
Originally Posted by mike.franky View Post
Cheers
Mike
Have you solved your problem?
I'm trying to understand your problem: are you simulating water evaporation under 15 °C (atmospheric pressure)? How could this be possible?
OpenFoam8 has a interface model to simulate this. However, its used temperatures about 400 K.
Vitor Monteiro is offline   Reply With Quote
Species Mole and Mass Fraction Macro combustion FLUENT 18 February 5, 2024 12:23
Error message: Insufficient Catalogue Size Paresh Jain CFX 32 February 3, 2021 03:37
Accessing the species mass fraction for particles data in UDF mac_09 FLUENT 17 August 9, 2017 20:15
PB: Saving mass fraction of species on two points with an udf biget.a FLUENT 2 July 23, 2009 03:06
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
