ERCOFTAC centrifugal pump case study 3D Mesh missing |
April 14, 2021, 00:57 |
Ranjith
Dear All,
I came across centrifugal pump test case "TurboECPGgi3D" provided on OpenFOAM Sig Turbomachinery page (URL), but I couldn't find the 3D mesh for running that case. I downloaded the files following the given instruction, svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_1.5/OSIG/TurboMachinery/ercoftacCentrifugalPump Downloaded folders have only 2D Mesh for stator and Rotor and I would like to get the 3D mesh. It would be a great help if someone can provide information about this test case. Thank you. |
June 9, 2022, 03:54 |
Vlad Popescu
Dear Ranjith,
Did you manage to find the 3D case? I am also looking for it. Many thanks, Vlad |
centrifugal pump, ercoftac, openfoam |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
ERCOFTAC centrifugal pump | vngrsrmn | OpenFOAM | 0 | June 20, 2012 06:51 |
Ercoftac centrifugal pump case study bug, Openfoam 1.6-ext (Floating point exception) | ArianeJasmin | OpenFOAM Programming & Development | 1 | April 4, 2012 14:11 |
Centrifugal Fan Case Study Results Required using CFX | kambireddy | CFX | 0 | October 8, 2010 05:46 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
