Parallel job run on multiple nodes - OpenFOAM |
June 15, 2022, 05:40 |
Amit Makhija
Rep Power: 8 |
Hello Foamers,
I am trying to run the OpenFOAM jobs on multiple nodes. However, I encountered some difficulties in doing so. Here is my job script. \\ script starts \\ #!/bin/bash #PBS -q small #PBS -l select=2:ncpus=40:vntype=cray_compute #PBS -l place=scatter #PBS -N refined_mach8_1 #PBS -j oe cd $PBS_O_WORKDIR blockMesh topoSet splitMeshRegions -cellZones -defaultRegionName fluid -overwrite decomposePar -allRegions -dict system/decomposeParDict mpirun -np 80 -oversubscribe chtMultiRegionFoam -parallel reconstructPar -allRegions \\ script ends \\ The issue is the cluster is acquiring two complete nodes, however, running the job only on one node. If anybody could provide valuable input, it would be conducive. |
OpenFOAM Running error with multiple nodes | dokeun | OpenFOAM Running, Solving & CFD | 1 | June 28, 2019 00:04 |
[snappyHexMesh] OpenFoam in parallel with sHM and sFE | pradyumnsingh | OpenFOAM Meshing & Mesh Conversion | 4 | October 26, 2018 16:25 |
OpenFOAM parallel on multiple nodes | FerdiFuchs | OpenFOAM Running, Solving & CFD | 1 | March 4, 2016 17:36 |
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker | rt08 | OpenFOAM Installation | 1 | February 28, 2016 19:00 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
