May 18, 2019, 08:12 |
Can't get residual plot for K and Omega ?!!!
Os
Rep Power: 8 |
Hello foamers,
I am making a simulation using the komega sst turbulence model and i am monitoring the residuals in real time but unfortunately i only get plots for the P Ux and Uy but cant get residual plots for the K and Omega ?! is there any suggestiong about how to resolve this issue?!! |
May 22, 2019, 03:04 |
Henrik Johansson
Rep Power: 8 |
Is the turbulence turned on? How are you monotoring your residuals? We need more information to help you. Read the following post if you wan't better help with our problems in the future: How to give enough info to get help Your problem can probably be solved by reading this thread: Tutorial of how to plot residuals !
/ Henrik Johansson |
May 22, 2019, 04:26 |
#3 | |
Os
Rep Power: 8 |
Thank you for the Reply , in order to plot the residuals i have inserted this line in the controlDict File the flowing line functions { #includeFunc residuals } Code:
application pimpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 5; deltaT 1e-5; writeControl adjustableRunTime; writeInterval 1e-2; purgeWrite 0; writeFormat binary; writePrecision 10; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; maxCo 0.9; functions { #includeFunc residuals forces { type forces; libs ("libforces.so"); writeControl timeStep; writeInterval 10; patches (wing); rho rhoInf; log true; rhoInf 1.2047; CofR (0 0 0); } forceCoeffs1 { // Mandatory entries type forceCoeffs; libs ("libforces.so"); patches (wing); // Optional entries // Field names p p; U U; rho rhoInf; rhoInf 1.2047; // rhoInf 1.204; // Reference pressure [Pa] pRef 0; // Include porosity effects? porosity no; // Store and write volume field representations of forces and moments writeFields yes; // Centre of rotation for moment calculations CofR (0 0 0); // Lift direction liftDir (0 1 0); // Drag direction dragDir (1 0 0); // Pitch axis pitchAxis (0 0 -1); // Freestream velocity magnitude [m/s] magUInf 10.578; // Reference length [m] lRef 1; // Reference area [m2] Aref 1; // Spatial data binning // - extents given by the bounds of the input geometry } } and In order to monitor the Residuals during the simulation runtime i use the command Code:
foamMonitor -l -r 1 postProcessing/residuals/0/residuals.dat & but as i said before the only curves i get are only for p Ux Uy and i dont get plots for k and Omega also the strange thing is once i directly open the file /postProcessing/residuals/0/residuals.dat i only can see residuals for P Ux and Uy and there is no sgine for the k and Omega residuals. Hope you can help me |
May 22, 2019, 10:23 |
Henrik Johansson
Rep Power: 8 |
I have never used that way to plot the residuals. I use either the way stated in the link I posted or using pyFoam: Code:
pyFoamPlotRunner.py theSolverIamUsing
May 23, 2019, 07:20 |
Rep Power: 12 |
read the manual: "The default fields whose residuals are captured are p and U. Should the user wish to configure other fields, they should make copy the residuals file in their system and edit the fields entry accordingly..
https://cfd.direct/openfoam/user-gui...hs-monitoring/ Last edited by mzzmrt; May 23, 2019 at 07:21. Reason: link added |
July 25, 2022, 06:23 |
yasmine
Rep Power: 3 |
Hi, could you please solve this problem? I am in the same case.
I would appreciate any help. Thanks in advance. |
July 25, 2022, 06:27 |
yasmine
Rep Power: 3 |
Hello foamers,
I am making a simulation using the komega sst turbulence model and i am monitoring the residuals in real time but unfortunately i only get plots for the P Ux and Uy but cant get residual plots for the K and Omega ?! is there any suggestiong about how to resolve this issue?!! Thanks in advance. |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
decompose dependent solution | arionfard | OpenFOAM | 3 | December 10, 2018 09:36 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
should Courant number always be kept below 1? | wc34071209 | OpenFOAM Running, Solving & CFD | 16 | March 9, 2014 19:31 |
