Energy -> temperature conversion failed to converge: |
September 15, 2022, 07:46 |
Twisampati Roy Chowdury
Rep Power: 3 |
From function static Foam::scalar Foam::species::thermo<Thermo, Type>::T(const ThermoType&, Foam::scalar, Foam::scalar, Foam::scalar, FType, dFdTType, LimitType, bool) [with ThermoType = Foam::species::thermo<Foam::hConstThermo<Foam:er fectGas<Foam::specie> >, Foam::sensibleInternalEnergy>; FType = double (Foam::hConstThermo<Foam:erfectGas<Foam::specie> >::*)(double, double) const; dFdTType = double (Foam::hConstThermo<Foam:erfectGas<Foam::specie> >::*)(double, double) const; LimitType = double (Foam::hConstThermo<Foam:erfectGas<Foam::specie> >::*)(double) const; Thermo = Foam::hConstThermo<Foam:erfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double]
in file /home/ubuntu/OpenFOAM/OpenFOAM-9/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 313 Energy -> temperature conversion failed to converge: iter Test e/h Cv/p Tnew 0 293.15 -89186.4 717.398 -3.39967e+23 1 -3.39967e+23 -2.43892e+26 717.398 -3.39967e+23 2 -3.39967e+23 -2.43892e+26 717.398 -3.39967e+23 3 -3.39967e+23 -2.43892e+26 717.398 -3.39967e+23 4 -3.39967e+23 -2.43892e+26 717.398 -3.39967e+23 5 -3.39967e+23 -2.43892e+26 717.398 -3.39967e+23 6 -3.39967e+23 -2.43892e+26 717.398 -3.39967e+23 7 -3.39967e+23 -2.43892e+26 717.398 -3.39967e+23 |
September 15, 2022, 10:33 |
September 15, 2022, 10:48 |
Rep Power: 3 |
I have tried visiting that thread. It did not help. I think my problem is different. I am not doing anything unrealistic in OpenFOAM 0 folder. Here is the link where you can accerss my OpenFOAM folder... --> https://drive.google.com/drive/folde...g1?usp=sharing
Energy Equ. based on temperature | Kummi | OpenFOAM | 4 | May 18, 2022 01:41 |
GAMG crash | fxzf | OpenFOAM Running, Solving & CFD | 6 | June 5, 2018 05:09 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Adding pressure and temperature sources instead of energy | rae | CFX | 3 | October 24, 2016 02:31 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 13:22 |
