Loosing geometry after snappyhexmesh for the ship |
October 17, 2022, 05:49 |
MS
Rep Power: 3 |
I am working with the DTMB geometry with a length of 5.72m (Lpp). When I execute snappyhexmesh I am loosing geometry as can be seen from attached figure. When I performed interfoam there is water inside the ship. I am attaching how my geometry look after executing snappyhexmesh (surface refinement level (0,0)).
I am also attaching another geometry of length of 2.5 m (Lpp). On this ship when snappy with a surface refinement of level (5,6) was performed, no loose of geometry was observed. The ship I mentioned in the first was taken from http://www.simman2008.dk/5415/5415_geometry.htm , the size of stl file is 1 Mb, but the ship I mentioned second (L=2.5m) has a size of 20 Mb. How I can rectify this issue. Is that because of lacking cad geometry repair, if so what repair work I should do for my ship. Any suggestion is welcomed and highly appreciated Waiting for a fast reply from someone Thanks and regards |
OpenFoam, snappyHexMesh and Salome for patches "top, bottom wall' | baezacaljo | OpenFOAM | 0 | May 6, 2021 15:26 |
Joints of a geometry not snapped well (SnappyHexMesh) | malini1408 | OpenFOAM Pre-Processing | 1 | April 15, 2019 12:09 |
Error in meshing a Ship hull using snappyhexmesh | Sachin m | OpenFOAM Pre-Processing | 1 | August 27, 2014 23:27 |
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry | villier | OpenFOAM Meshing & Mesh Conversion | 17 | June 15, 2010 19:51 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
