November 2, 2022, 13:42 |
InterFoam generating stack trace
Diego Rodrigo
Rep Power: 3 |
trying to do a case where flow is going through 3 inlets of a 2.5D geometry When i run interFoam, the case goes till time 145.052 and stop running with back trace error. Can anyone help me with this issue. Any suggestion will be aprecciated. Thank you. fvScheme Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { div(rhoPhi,U) Gauss linearUpwind grad(U); div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } Code:
solvers { "alpha.water.*" { nAlphaCorr 2; nAlphaSubCycles 1; cAlpha 1.5; MULESCorr yes; nLimiterIter 3; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; } pcorr { solver PCG; preconditioner DIC; tolerance 1e-5; relTol 0; } pcorrFinal { solver PCG; preconditioner DIC; tolerance 1e-5; relTol 0; } p_rgh { solver PCG; preconditioner DIC; tolerance 1e-08; relTol 0.05; } p_rghFinal { $p_rgh; relTol 0; } U { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-08; relTol 0; } } PIMPLE { momentumPredictor no;//solve Navier-Stokes equations explicitly nOuterCorrectors 1;//number of outer correctors nCorrectors 3;//number of pressure - velocity coupling iterations nNonOrthogonalCorrectors 0;//number of pressure iterations } relaxationFactors { equations { ".*" 1;//no under-relaxation in this case } } |
Generating Stack Trace while solving | johny_walker | OpenFOAM Running, Solving & CFD | 1 | January 29, 2021 03:48 |
SimpleFoam generating stack trace & failing to solve | rakesh.a | OpenFOAM Running, Solving & CFD | 9 | May 14, 2019 08:02 |
Doxygen documentation | Tanay | OpenFOAM Installation | 9 | September 23, 2011 11:40 |
ParaView and Qt 4.3.5 on Mac OS X 10.6 | Adrian | OpenFOAM | 3 | August 8, 2010 03:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
