Command 'blockMesh' not found
Like Tree1Likes
  • 1 Post By fanta
Old   March 6, 2023, 18:07
Cool Command 'blockMesh' not found
gus_champs is on a distinguished road
Hi, I am an absolute starter on Openfoam, and as I was going through OpenFOAM's Wiki learning path video, I was stuck when trying to create a mesh from one of the tutorial cases using the blockMesh command. I have been trying for hours but still could not figure it out what is causing this problem:
Command 'blockMesh' not found, but can be installed with:
sudo apt install openfoam
I am confused because the video from the tutorial did not go through any installation of a mesher, as he wrote the commands (which I did exactly like him) the mesh started to be generated.
Can someone help me to solve this problem?
Thankfully,
Gustavo
gus_champs is offline   Reply With Quote
Old   March 7, 2023, 02:20
fanta is on a distinguished road
What Video did you watch? Did you source the OpenFOAM Environment?
fanta is offline   Reply With Quote
Old   March 7, 2023, 13:17
I follow the video from OpenFoam's Wiki, from József Nagy.
https://youtu.be/CeEJS1eT9NE
Those are the steps that I took (in the picture). I am sorry, but what exactly it is to source OpenFoam?
Old   March 7, 2023, 23:32
Sorry i cannot help you further, because this is for the WSL. I use native Linux and have no experience with OpenFOAM and the WSL. But Mr Nagy explained how to source OpenFOAM in Chapter 7 of his Video (ca. 10:51 on). So far so good.
gus_champs likes this.
begginer, blockmesh, tutorial
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 15:11
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
