foam-extend: different empty (2-D) directions
Old   August 28, 2019, 12:44
Question foam-extend: different empty (2-D) directions
Michael@UW is on a distinguished road
Does anybody have any idea how to deal with the following error?
I encounter the error when running foam-extend 4.1 in parallel "Some processors detect different empty (2-D) directions. Probably using empty patches on a bad parallel decomposition".
My empty direction is along x-axis. I tried different decomposing methods in decomposeParDict file and the domain is successfully decomposed as expected. , but it keeps giving the same error. The error pops up at the first time step most of the time, sometime after some iterations. By the way, I am using sixDoFRigidBodyDisplacement boundary condition (0/pointDisplacement) and the solver is interDyMFoam.
The case runs well in serial mode.
decomposeParDict:
numberOfSubdomains 2;
method simple;
//method scotch; //same error
//method metis; //same error
simpleCoeffs
n ( 1 2 1 );
delta 0.001;
Michael@UW is offline   Reply With Quote
Old   November 4, 2019, 06:21
Hojatollah Gholami
Hgholami is on a distinguished road
Dear Michael@UW
I have the same problem with cyclic boundary condition and dynamic mesh (fsiFoam). Do you resolve it?
Hgholami is offline   Reply With Quote
Old   November 4, 2019, 12:25
No. I have not solved this issue. But I found the inconsistent empty direction is caused by the dynamic mesh motion; there is an unexpected rotation to make the mesh of the empty patch not on the same plane. I constrain the object but it still produces some motion along the direction which is not supposed to have.
Old   November 8, 2019, 02:22
Hojatollah Gholami
As your tip, I separate cyclic boundary condition to multi part and use "preservePatch" in decomposeDict to add each part to a processor. I think it works.
Old   November 24, 2019, 21:13
That's a good way! I may try that later. Recently I learned there is a tool name flattenMesh which can make the patch flat, but I haven’t tried it.
Old   May 11, 2023, 01:52
Hojjat is on a distinguished road
I also get the same error in FE4.1. In the error description there is a mention of increasing 'emptyDirectionTolerance' in controlDict, which I couldn't make it work.
What I did to solve the issue was to reduce my number of processors in decomposeParDict by one. For example changing 6 to 5. I think dividing a number to 5 produces a rounder number so round-off error is increased and more manageable.
Hojjat is offline   Reply With Quote
empty direction, foam-exend
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 07:53
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
