How to specify continuous phase (water) diameter in multiphaseEulerFoam or twophasee |
May 17, 2023, 13:14 |
Vivekananda
Rep Power: 9 |
Currently I am working on bubble column simulation in 2 D. I am using water and air as continuous and dispersed phases. I am a bit confused as I see the transport properties or phase properties file that the water diameter needs to be given. I understand that in eulerian approach diameter of the two phases has to be given , but as water is continuous and it never forms bubble in the practical experiment, so what value should I give in water diameter. Should I keep it large like say, around 1 meter so that it becomes the continuous phase? If you can throw some lights it will be very helpful. Regards |
May 22, 2023, 13:38 |
Humberto
Rep Power: 5 |
That's correct, depending on the type defined in the blending, however if it is defined as none the continuous phase can be considered as 1. An example is the fluidizedbed tutorial. The openfoam in the bubble column case is linear type in blending, so the phases are not fully continuous or dispersed, so the particle diameter has to be specified.
I believe that the diameter to be specified is the diameter of the water particle. Which influences the interphase term of the momentum equation. |
multiphaseeulerfoam, openfoam, twophaseeulerfoam |
multiphaseEulerFoam mass transfer / phase transfer | geth03 | OpenFOAM Running, Solving & CFD | 0 | January 16, 2023 09:40 |
Two-phase flow _Problem with phase diameter divergence | esma | Fluent Multiphase | 1 | January 8, 2020 14:51 |
For a single phase flow, is there any way to check water surface level? | Tanjina | FLUENT | 0 | February 23, 2014 22:56 |
Two continuous phase and One dispersed phase | Michael | CFX | 2 | January 14, 2010 15:19 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
