How to build a coupling boundary conditions of a multi-region solver |
October 11, 2023, 06:40 |
Fan
Rep Power: 2 |
Hi guys,
I tried to build a multi-region solver fo solving neutron diffusion equation. However, difficulties are encountered when the coupling boundary between regions is given. The default solver use the compressible::turbulentTemperatureCoupledBaffleMix ed boundary,how to modify it for satisfying the neutron flux volscalarfield?It is also necessary to meet the same continuity and heat flux. |
coupling boundary |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
