Negative Size requested- cartasianMesh
Old   January 26, 2024, 08:07
Default Negative Size requested- cartasianMesh
Zomzzz is on a distinguished road
Hello, i am facing a problem to create mesh through openfoamv2012
i am still beginner in using OF and not that clever and i really need help
i am trying run cartasinMesh command in open foam the model is a bit huge
every time i try to run that mesh command i get error negative size requested
i searched hardly through internet and i found two different threads and the solution was to change label size to 64
but how to change that label size to 64 no idea,
I tried to write
export WM_LABEL_SIZE=64
and nothing changed
i tried
source $home/openfoam/etc/bashrc  WM_LABEL_SIZE=64
it said no such file or directory
i have enough ram and cores as i am running it on cloud windows
could anyone help me to solve this problem.
Zomzzz is offline   Reply With Quote
Old   January 28, 2024, 03:14
any help, please?
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets Struggle_Achieve OpenFOAM Meshing & Mesh Conversion 3 June 17, 2019 09:29
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 11:27
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
