[Sponsors] | |||||
Predicted Cd is dependent on time step (pimpleFoam) |
Dongyue Li
Rep Power: 19 ![]() |
In this test case, a Re = 1.5e4 single phase flow around a cylinder was simulated. It was found the predicted Cd is dependent on deltaT.
When deltaT=1e-4, time averaged Cd equals 1.19, which match the experiments (Cd=1.2). When deltaT=1e-5, time averaged Cd equals 1.6, which is much higher. Please see the attached picture. Run the test case by OpenFOAM-10. See the value of Cd change deltaT=1e-5, see the value of Cd In a laptop, one can run the test case in serial for 300s-400s to see the variation of Cd. This is also reported here: https://bugs.openfoam.org/view.php?id=4059 Test case link: https://drive.google.com/file/d/1LaS...usp=drive_link
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html |
Dongyue Li
The bug report is closed by OpenFOAM foundation.
Please also see the last pages of this: https://www.tfd.chalmers.se/~hani/ku...es/ddtCorr.pdf It looks this problem comes from ddtcorr implementation.
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html Last edited by sharonyue; March 5, 2024 at 11:28. |
Rep Power: 10 ![]() |
as Henry Weller already mentioned, the Courant Number is too large obviously for your simulation and Courant Number independency is achieved for Co<<1.
Dongyue Li
1. Co<<1 does not provide the correct results. I tried 0.01, it predicts high Cd value.
2. Providing Co < 1, results should not be very time dependent. A little bit difference should be acceptable. 3. It does not make sense using a smaller time step, but the results are worse. At least it cannot be justified by theory (sometims it happens though), especially for such a easy single phase test case. 4. https://www.tfd.chalmers.se/~hani/ku...es/ddtCorr.pdf In this slide, they also found with ddtcorr, it predicts higher Cd. Exactly the same problem in my test case. These days I use the pimpleFoam provided by ESI OpenFOAM-v2306, whereas the ddtcorr is turned off. It does not have this problem.
#5 | |
Roland
Rep Power: 18 ![]() |
ddtCorr may be switched off, but default on: https://www.openfoam.com/documentati...10b5389e09c0b4 |
Dongyue Li
Alright, so, I have no idea what happens. It requires lots effort to debug. I think it comes from the algorithm instead of coding errors.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 43 | October 28, 2025 04:19 |
| Postprocess: sampleDict works but creates no output folder | shock77 | OpenFOAM Post-Processing | 14 | November 15, 2021 09:27 |
| pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
| dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
| mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
