self-imported Mesh solved by icoFoam
Old   March 4, 2024, 00:56
Default self-imported Mesh solved by icoFoam
Tianyang Fang
FangTianyang is on a distinguished road
Hello guys,
I am really new to OPENFOAM. I made a 3-D mesh in Pointwise and exported into the following form as can be seen in the attachment. I just realized that there is no pointZone file in the exported polyMesh and I don't know if that affects the running of icoFoam.
the boundary file looks like the following:
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
5
Buttom
type wall;
nFaces 244000;
startFace 72814000;
Top
type wall;
nFaces 244000;
startFace 73058000;
Wall
type wall;
nFaces 244000;
startFace 73302000;
inlet
type patch;
nFaces 20000;
startFace 73546000;
outlet
type patch;
nFaces 20000;
startFace 73566000;
and I revised p and U file according to my boundary file as this:
p file:
| \\ / O peration | Version: v2106 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
Top
type zeroGradient;
Wall
type zeroGradient;
Buttom
type zeroGradient;
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
and the U file looks like this:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0 -5 0);
Wall
type fixedValue;
value uniform (0 0 0);
Top
type zeroGradient;
Buttom
type fixedValue;
outlet
type zeroGradient;
after that, I have created a file called All which include only the command icoFoam. So I expect that when every time I submit the ./All, icoFoam will run.
and it turns out to be this:
Create time
Create mesh for time = 0
PISO: Operating solver in PISO mode
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.005
Courant Number mean: 0.000130326 max: 0.00887154
smoothSolver: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
after the that the machine exceed maximum time of running and automatically shut the process.
If you have any suggestions or even just some keyword you would like to share with me. Please feel free to contact me. Thank you sooooooo much.
Best,
Tianyang
FangTianyang is offline   Reply With Quote
flow over cylinder in openFoam saeed jamshidi OpenFOAM Pre-Processing 3 August 11, 2023 15:16
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 12:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
