March 4, 2024, 02:55 |
cartesianMesh command not found
Rep Power: 2 |
hi, i was always using openfoam 2012 and use these commands to generate the mesh:
surfaceFeatureExtract surfaceFeatureConvert constant/triSurface/RegionSTL.eMesh eMesh.obj cartesianMesh after i installed openfoam 2312 and i tried to do the same commands but i got and error saying cartesianMesh command not found any solution to this problem |
March 4, 2024, 03:18 |
Yann
Rep Power: 26 |
cartesianMesh is still in v2312 for me. Does surfaceFeatureExtract works in v2312 on your side? Yann |
March 4, 2024, 04:36 |
Rep Power: 2 |
yes all commands before cartesianmesh are working normally
the thing that i changed wm label size to 64 and then i recompile with .//ALLwmake -j and after it fnished i faced this problem i installed openfoam through this sudo apt-get install openfoam2312-default |
March 4, 2024, 05:01 |
Yann
Rep Power: 26 |
It might be a compilation issue then.
Did it successfully compile without any error? An old thread about 64bits label size: utilities with 32 bit labels works but 64 does not |
Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 15:11 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 01:36 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
