Error when using Crank Nicolson ddt scheme
Like Tree1Likes
  • 1 Post By JNSN
Old   March 5, 2024, 18:29
Default Error when using Crank Nicolson ddt scheme
Pedro Gouveia
unilord is on a distinguished road
Hey guys,
I am performing a centrifugal pump simulation in OF11. At the moment I am trying a transient approach, since I have already ran all the steady state simulations I needed. The transient simulation is started with the results from the steady state simulation, since I do not care for the startup of the pump. It runs at 620 rpm, with 0.0063m^3/s flow rate. It is a relatively small pump. The simulation is dynamic, using the sliding mesh approach and the new Non Conformal Coupling feature from the foundation branch.
I am using vanLeer schemes for turbulence (using kEpsilon model) and LUST for convective term. No cell/face limiters are being used (although I already tried and it didn't improve anything). When using Euler for the ddt schemes, no error appears. However, when using Crank Nicolson 0.1 to 0.9 a floating point exception occurs.
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 3 with PID 0 on node omnideayoga-Yoga-Slim-7-Pro-14ARH7 exited on signal 8 (Floating point exception).
This is my mesh quality parameters:
Mesh stats
    faces:            2283864
    internal faces:   2148432
    cells:            741672
    faces per cell:   5.97609
    boundary patches: 30
    point zones:      0
    face zones:       3
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     723936
    prisms:        17736
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 3
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0/cellToRegion"
  <<Writing region 0 with 335968 cells to cellSet region0
  <<Writing region 1 with 246432 cells to cellSet region1
  <<Writing region 2 with 159272 cells to cellSet region2
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    NCC3_2              6976     7412     ok (non-closed singly connected)
    wall_3_2            1680     1802     ok (non-closed singly connected)
    wall_3_3            2000     2142     ok (non-closed singly connected)
    wall_3_4            2240     2397     ok (non-closed singly connected)
    wall_3_layers       28276    28964    ok (non-closed singly connected)
    wall_tongue_1       128      153      ok (non-closed singly connected)
    wall_3_1            1360     1462     ok (non-closed singly connected)
    wall_tongue_2       128      153      ok (non-closed singly connected)
    wall_tongue_3       160      187      ok (non-closed singly connected)
    outlet              784      850      ok (non-closed singly connected)
    wall_4              4480     4794     ok (non-closed singly connected)
    wall_4_layers       13720    14100    ok (non-closed singly connected)
    NCC2_1              2432     2584     ok (non-closed singly connected)
    NCC2_3              6976     7412     ok (non-closed singly connected)
    blade_LE            320      408      ok (non-closed singly connected)
    blade_pressure      7808     8364     ok (non-closed singly connected)
    blade_suction       7936     8500     ok (non-closed singly connected)
    blade_tip           448      544      ok (non-closed singly connected)
    wall_2              30804    31908    ok (non-closed singly connected)
    inlet               1852     1899     ok (non-closed singly connected)
    NCC1_2              2432     2584     ok (non-closed singly connected)
    wall_1              12492    12691    ok (non-closed singly connected)
    nonConformalCouple_12_on_NCC1_20        0        ok (empty)
    nonConformalCouple_12_on_NCC2_10        0        ok (empty)
    nonConformalCouple_23_on_NCC2_30        0        ok (empty)
    nonConformalCouple_23_on_NCC3_20        0        ok (empty)
    nonConformalError_on_NCC2_30        0        ok (empty)
    nonConformalError_on_NCC1_20        0        ok (empty)
    nonConformalError_on_NCC3_20        0        ok (empty)
    nonConformalError_on_NCC2_10        0        ok (empty)
Checking geometry...
    Overall domain bounding box (-0.153983 -0.18447 -0.0123) (0.220992 0.482614 0.1647)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (-3.87232e-17 -5.16145e-18 -6.18043e-16) OK.
    Max cell openness = 3.32906e-16 OK.
    Max aspect ratio = 13.8188 OK.
    Minimum face area = 9.82531e-08. Maximum face area = 1.4498e-05.  Face area magnitudes OK.
    Min volume = 1.23456e-10. Max volume = 2.82255e-08.  Total volume = 0.00389344.  Cell volumes OK.
    Mesh non-orthogonality Max: 54.0036 average: 7.95413
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 2.97155 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
These are my fvSchemes
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  11
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default        CrankNicolson 0.5;
gradSchemes
    default        Gauss linear;
divSchemes
    default                                     none;
    div(phi,k)                                 bounded Gauss vanLeer;
    div(phi,epsilon)                         bounded Gauss vanLeer;
    div(phi,U)                                 bounded Gauss LUST grad(U);
    div((nuEff*dev2(T(grad(U)))))   bounded Gauss linear;
laplacianSchemes
    default        Gauss linear corrected;
interpolationSchemes
    default        linear;
snGradSchemes
    default        corrected;
wallDist
    method Poisson;
These are my fvSolutions
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver                    GAMG;
        tolerance                 1e-08;
        relTol                    0.01;
        smoother                  GaussSeidel;
        nCellsInCoarsestLevel     1000;
        //nSweeps                   200;
        minIter                   5;
    pFinal
        $p;
        tolerance          1e-08;
        relTol              0.0;
    "pcorr.*"
        $p;
        tolerance          1e-03;
        relTol              0.0;
    U
        solver          smoothSolver;
        tolerance       1e-08;
        //nSweeps         200;
        relTol          0.01;
        //type            coupled;
        //solver          PBiCGStab;
        //preconditioner  DILU;
        //tolerance       (1e-08 1e-08 1e-08);
        //tolerance       1e-14
        //relTol          (0 0 0);
        //relTol          0.0;
        minIter         3;
    UFinal
        $U;
        tolerance    1e-10;
        relTol        0.0;
    "(k|epsilon|omega)"
        tolerance       1e-08;
        relTol          0.01;
        //nSweeps         50;
        minIter        2;
     "(k|epsilon|omega)Final"
        tolerance       1e-10;
        relTol          0.0;
        //nSweeps         50;
        minIter        2;
    MeshPhi
        smoother      symGaussSeidel;
        tolerance     1e-2;
        relTol        0.0;
potentialFlow
    nNonOrthogonalCorrectors 10;
PIMPLE
    correctMeshPhi          yes;
    momentumPredictor         yes;
    nNonOrthogonalCorrectors  2;
    nCorrectors               2;
    nOuterCorrectors          30;
    residualControl
        p        1e-8;
        U        1e-10;
        k        1e-8;
        epsilon        1e-8;
relaxationFactors
    fields
        p               0.3;
        pFinal          1;
    equations
        "(U|k|omega)"            0.7;
        "(U|k|omega)Final"       1;
basically it happens once it enters the second time step. Doesn't really matter how many outer iterations I run. Does someone have an idea of what might be happening? The complete log of the simulation is presented in the attached file.
unilord is offline   Reply With Quote
Old   March 6, 2024, 08:22
JNSN's Avatar
Jan
JNSN is on a distinguished road
Hi Pedro,
I have just checked with a test case based on the propeller tutorial and can reproduce the behaviour. For a case with moving mesh (solid body rotation) in combination with NCC the sovler crashes at second time step as soon as one uses CrankNicolson ddtScheme.
I think, this is most likely due to the NCC, and there are some values (fluxes or whatever) required from the previous time step, but are not available. Looks like this is eihter a bug or the combination of NCC and secondOrder time integration is not (yet) implemented.
If you really require CrankNicolson, you may prepare a simple test case and submit a bug report.
Btw, any reason for using such huge amount of outer correctors?
Best,
Jan
JNSN is offline   Reply With Quote
Old   March 6, 2024, 09:02
Pedro Gouveia
Originally Posted by JNSN View Post
Hi Pedro,
Best,
Jan
Hey Jan,
Do you know how can I submit a bug report? I tried with the backward scheme and everything works fine.
The reason I am using this many outer correctors is because I read that we should not limit the pimple iterations, but use a convergence criteria so that the cycle exits automatically before the max number of outer iterations.
However, when I do that, nothing really happens. I am using this fvSolution:
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver                    GAMG;
        tolerance                 1e-06;
        relTol                    0.1;
    pFinal
        $p;
        relTol			  0.0;
    "pcorr.*"
        $p;
        tolerance		  1e-03;
        relTol			  0.0;
    U
        tolerance       1e-06;
        relTol          0.1;
    UFinal
        $U;
        relTol		0.0;
    "(k|epsilon|omega)"
        tolerance       1e-06;
        relTol          0.01;
        relTol          0.0;
        //nSweeps         50;
        minIter		2;
    MeshPhi
        tolerance 	1e-2;
        relTol    	0.0;
potentialFlow
PIMPLE
    correctMeshPhi	      yes;
    nCorrectors               2;
    residualControl
    	p		1e-5;
    	U		1e-6;
    	//k		1e-8;
    	//epsilon		1e-8;
    	//".*"		1e-5;
relaxationFactors
    fields
        p               0.4;
        pFinal          1;
    equations
        "(U|k|omega)"            0.4;
as you can see, I am limiting the residual to a minimum of 1e-5 for p and 1e-6 for U. The log file is attached. I don't understand why the pimple cycle keeps going on even when performing 0 iterations for both p and U. the values do change a bit, but I dont understand why if no iterations are being performed. Also, one thing I noticed is that on the final iteration (for this case iter=30), when there is no under relaxation, the residuals of the pressure increase substantially (from e-7 to e-1). Is there any reason for this? In the tutorials I see this does not happen.
Old   March 6, 2024, 09:29
JNSN's Avatar
Jan
Ok, interessting. If it runs with backward scheme, it seems to be a specific problem of CrankNicolson, not of 2nd order time schemes in general.
As the backward scheme is much more stable (with similar accuracy than CN) , it suggest to use this is your simulations.
Bugs can be reported via: https://bugs.openfoam.org/rules.php
I would not use the residual control, and just set the outer correctors to a fixed number (3 to 5 is usually fine, but depend on the case (mesh, time step, flow type) and the piso ( nCorrectors) to 1.
Kummi likes this.
Old   March 6, 2024, 09:31
Pedro Gouveia
Just to note, one thing I noticed is that, on lines 49 and 50 of the file I uploaded in post #3, it displays a message saying that no corrector convergence criteria was found. Maybe this is why it is not exiting. However I can not find a way to define the convergence corrector criteria.
Second-order backward differencing vs Crank Nicolson Beans8 Main CFD Forum 7 June 23, 2023 05:59
Implementtaion of Crank Nicolson scheme in OpenFOAM hchen OpenFOAM Running, Solving & CFD 5 May 6, 2020 15:25
Crank Nicolson scheme implemented wrong? rajibroy OpenFOAM Programming & Development 10 May 5, 2020 10:57
Crank Nicolson scheme msrinath80 OpenFOAM Running, Solving & CFD 6 November 14, 2010 14:59
Crank Nicolson scheme contd msrinath80 OpenFOAM Running, Solving & CFD 0 December 12, 2006 23:41
