Blockmesh error while running Checkmesh
Old   March 7, 2024, 14:02
Default Blockmesh error while running Checkmesh
jky
jay
jky is on a distinguished road
Hi all!
I am trying to generate wedge geometry a mesh about flow inside the cylinder to model turbulence, when I run checkmesh I got below two error, I cannot understand why it doesn't work also I am getting very high skewness, I appreciate any help or ideas to solve this problem.
Checking basic pointZone addressing...
No pointZones found.
Checking geometry...
Overall domain bounding box (0 0 -6.09235e-06) (0.06 0.02 6.09235e-06)
Mesh has 2 geometric (non-empty/wedge) directions (1 1 0)
Mesh has 3 solution (non-empty) directions (1 1 1)
Wedge frontnozzle with angle 0.0174533 degrees
Wedge fronttube with angle 0.0174532 degrees
Wedge frontambient with angle 0.0174533 degrees
Wedge backnozzle with angle 0.0174533 degrees
Wedge backtube with angle 0.0174532 degrees
Wedge backambient with angle 0.0174533 degrees
***Number of edges not aligned with or perpendicular to non-empty directions: 3981
<<Writing 7863 points on non-aligned edges to set nonAlignedEdges
Boundary openness (-1.84901e-19 -6.55897e-17 -1.75431e-14) OK.
Max cell openness = 2.77411e-15 OK.
Max aspect ratio = 9.9 OK.
Minimum face area = 4.96695e-13. Maximum face area = 1.95e-07. Face area magnitudes OK.
Min volume = 1.7764e-17. Max volume = 1.93006e-13. Total volume = 3.11588e-09. Cell volumes OK.
Mesh non-orthogonality Max: 89.9986 average: 17.2443
*Number of severely non-orthogonal (> 70 degrees) faces: 5853.
Non-orthogonality check OK.
<<Writing 5853 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
***Max skewness = 285.158, 6007 highly skew faces detected which may impair the quality of the results
<<Writing 6007 skew faces to set skewFaces
Coupled point location match (average 0) OK.
Failed 2 mesh checks.
End
regards
jay
jky is offline   Reply With Quote
[blockMesh] OpenFOAM blockMesh bus error BRH OpenFOAM Meshing & Mesh Conversion 0 April 12, 2021 12:02
[mesh manipulation] checkMesh Erros after refineMesh mgdenno OpenFOAM Meshing & Mesh Conversion 10 October 14, 2014 06:16
Possible bug in blockMesh benru OpenFOAM Bugs 16 August 17, 2013 20:54
checkMesh Errors after refineMesh mgdenno OpenFOAM 0 July 30, 2012 22:39
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
