How to determine if a cell is on a boundary in OpenFOAM?
Old   March 25, 2024, 08:18
Default How to determine if a cell is on a boundary in OpenFOAM?
applekiller is on a distinguished road
Hello, everyone.
In programming I want to determine if a cell is on boundary. Is there any way to solve it?
I originally wanted to judge whether the face of the cell was in a boundary patch, but felt that cost too much calculation. I look forward to your thoughts.
applekiller is offline   Reply With Quote
Old   March 25, 2024, 14:43
Shravan
Severus is on a distinguished road
Check out this thread: Finding boundary cells
Also check out (based on the this answer in the above thread): https://www.openfoam.com/documentati...aryToCell.html
Thanks
Severus is offline   Reply With Quote
Old   March 25, 2024, 22:13
Thanks
Thank you!
Another question is, what is the pattern of grid arrangement in OpenFOAM? Is it that the internal cells are arranged first and then the boundary cells
Old   March 27, 2024, 11:45
Shravan
I am not a 100% sure, please correct me if I am wrong. I recommend you to print it out if possible and check for yourself.
For the cells, I think the arrangement is based on axis (at least for structured ones). For a specific x axis value, it is fixed and y and z are numbered for that constant x value. Then x is incremented and the same procedure is followed till all the values of x is reached, by that time you would have covered all the cells (similar to the contant/polyMesh/points file). For the faces however, I have heard that it is first internal and then boundary faces. I think decomposition may also influence this (for parallel simulations where the domain is decomposed into several smaller subdomains).
Thanks
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
