June 22, 2009, 08:26 |
paraview,need recompile?
quinton
Rep Power: 16 |
hi!
I have a problem with paraview. i have installed openfoam1.5, and with the first example cavity running, the paraFoam tell me you should select "a reader for cavity.OpenFOAM", so i search all around the forum.... then i get the answer: recompile the paraview and vtk. yes i did , and paraFoam run good! but yesterday, i found i need openfoam1.5-dev. so, i built the openfoam1.5-dev. then run the first case cavity, oh! the same hints like i first use of1.5 "a reader for cavity.OpenFOAM" should be selected. MY God! did i need recompile the paraview again?!!@? then i chanaged the bash script file for the of1.5, the paraFoam run good! and changed to of1.5-dev. "a reader for cavity.OpenFOAM" hint shocks me again! i think that i need not recompile the paraview , it must be some script files to be modified, may be dirctories etc..... what should i do? thanks advance...... Best Regards! |
Transient boundary conditions | Jarrod Sinclair (Sinclair) | OpenFOAM Running, Solving & CFD | 133 | May 6, 2015 06:21 |
Compiling with exe option | maka | OpenFOAM Pre-Processing | 9 | September 16, 2011 18:54 |
MRFSimpleFoam amp cyclic patches | david | OpenFOAM Running, Solving & CFD | 36 | October 21, 2008 21:55 |
Recompile turbulence model in OpenFoam | qtian | OpenFOAM Running, Solving & CFD | 7 | November 26, 2007 15:51 |
Installation of 13 | grtabor | OpenFOAM Installation | 14 | August 24, 2006 12:43 |
