Temperature Gradient at Wall
Like Tree9Likes
  • 6 Post By santos
  • 1 Post By svens
  • 2 Post By santos
Old   June 23, 2009, 13:48
Default Temperature Gradient at Wall
Sven Winkler
sven is on a distinguished road
I am simulating a laminar channel flow with heated walls. To calculate y nusselt number I first want to calculate the temperature gradient at the wall. Unfortunately I couldnt find some function similar to "WallGradU" which is able to calculate the wall temperature gradient, like "WallGradU" does it for the velocity gradient. Has anyone an idea how I could get the temperature gradient out of OpenFOAM? Can the "WallGradU" function be edited to get the temperature gradient?
sven is offline   Reply With Quote
Old   June 23, 2009, 22:18
Jitao Liu
awacs is on a distinguished road
Hi sven,
I am interested in this problem too. I am new to OpenFOAM. I want to simulate the filling process of non-newtonian fluids into a heated cavity.The energy equation was added to the interFoam solver to calculate the temperature field.
At the heated wall:
1) The temperature of non-newtonian fluid is assumed equal to the wall's (in my case,the thermal conductivity of the wall is much larger than that of the non-newtonian fluid ).
2) A coupled solver such as chtMultiRegionFoam can be created to solve this problem. Combination of heatConductionFoam and interHeatFoam (interFoam with energy equation) for conjugate heat transfer between a solid region and fluid region.
I am working on the second part.
If there is any development, please let me know.
Best regards,
Jitao
awacs is offline   Reply With Quote
Old   June 24, 2009, 04:27
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Hi Sven,
Make a copy of wallGradU, replace U with T, volVectorField with volScalarField and dimensionedVector with dimensionedScalar. It should work!
Regards,
Jose Santos
EleCr, Hamoon, mizzou and 3 others like this.
santos is offline   Reply With Quote
Old   June 24, 2009, 12:16
Sven Schweikert
svens is on a distinguished road
Hi Santos - thanks for your reply.
I have the same intention like sven and tried your advise.
Sadly I received some errors while creating the new wallGradT:
Line 80 - error: Expected primary-expressions before '(' token
Line 83 - error: 'scalar' is not a class of namespace
PHP Code:
#include "fvCFD.H"
int main(int argcchar *argv[])
timeSelector::addOptions();
#include "setRootCase.H"
#   include "createTime.H"
instantList timeDirs timeSelector::select0(runTimeargs);
#   include "createMesh.H"
forAll(timeDirstimeI)
runTime.setTime(timeDirs[timeI], timeI);
Info<< "Time = " << runTime.timeName() << endl;
IOobject Theader
"T",
runTime.timeName(),
mesh,
IOobject::MUST_READ
// Check U exists
if (Theader.headerOk())
mesh.readUpdate();
Info<< "    Reading T" << endl;
volScalarField T(Theadermesh);
Info<< "    Calculating wallGradT" << endl;
volScalarField wallGradT
IOobject
"wallGradT",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar
(                                                 <- line 80
"wallGradT",
T.dimensions()/dimLength,
scalar::zero                              <- line 83
forAll(wallGradT.boundaryField(), patchi)
wallGradT.boundaryField()[patchi] =
T.boundaryField()[patchi].snGrad();
wallGradT.write();
        else
Info<< "    No T" << endl;
Info<< "End" << endl;
    return
0;
I am an absolutely beginner and I didn't find a solution for these errors so far.
About some additional help I would be really helpful.
Thanks a lot & regards
svens
Luttappy likes this.
svens is offline   Reply With Quote
Old   June 24, 2009, 12:20
santos's Avatar
Jose Luis Santos
Replace scalar::zero with 0 and all should be well.
Regards,
Jose Santos
Hamoon and stathisk like this.
Old   June 24, 2009, 15:23
Sven Schweikert
It works! Perfect - thanks so much.
Old   July 23, 2010, 05:04
n/a
deji is on a distinguished road
Question: I am able to compute the mean temperature gradient at a specified patch of my choosing. The is essentially 3D, hence the I have a 2D plane wall temperature gradient. Can anyone give me any feedback or advice as to how I can average the temperature gradient along a wall direction, so that I end with an output that comprises two columns such as: x dTmean/dn
x1 *****
x2 *****
Thanks.
Deji
deji is offline   Reply With Quote
Old   November 1, 2010, 17:25
farhagim is on a distinguished road
Hello Jitao,
I would like to know if you were successful with your implementation. I am interested in such a coupled solver ( combination of heatConductionFoam and interHeatFoam ). I would be so grateful if you can help me.
Thanks,
Mehran
Originally Posted by awacs View Post
Hi sven,
At the heated wall:
Best regards,
Jitao
farhagim is offline   Reply With Quote
Wall Normal Temperature Gradient Daniel Tanner FLUENT 6 September 20, 2015 13:10
how to get the change of temperature of a wall shoeb Siemens 2 November 30, 2004 13:44
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Help,UDF for temperature derivatives in wall. jwt FLUENT 0 August 17, 2002 08:17
Direct calculation of temperature gradient J.W.Ryu FLUENT 5 December 27, 2001 06:39
