interDyMFoam gamma fluxes with topology change
Old   July 24, 2009, 11:20
Default interDyMFoam gamma fluxes with topology change
Sean McIntyre
sean_mcintyre is on a distinguished road
I'm trying to use interDyMFoam for the simulation of water entry. The geometry is similar to the movingConeTopo tutorial, with different shapes and some more grid refinement, plus a gamma field. Anyway, the solution seems to chug along nicely until the interface interacts with the cell addition zone (or removal? - I haven't checked that, as the removal zone was under the water). It seems that the gamma fluxes might get swapped (phase 1 for phase 2, or vice versa) in those cells. With a density ratio of 1, this doesn't cause stability issues, but when some quantity of water gets made into air (I think), that it generates pd spikes, eventually leading to a crash.
Has anyone else experienced this? If so, is there an easy enough fix?
Thanks,
Sean McIntyre
sean_mcintyre is offline   Reply With Quote
Old   July 24, 2009, 11:32
Nikolaos Spyrou
nikos_fb16 is on a distinguished road
which timediscretisation do you use? If its not euler try again with euler.
I had some problems with the rayleigh taylor instability and interdymfoam, that were related to the timescheme.
Nikos
nikos_fb16 is offline   Reply With Quote
Old   July 24, 2009, 12:09
Sean McIntyre
I'm just trying to get a really simple case set up, so the schemes are plain Euler for time, first and second order things for space discretization. Also, if I have it write the solution really often, I can see the strange happenings in pd at the mesh extrusion layer, as opposed to the fluid-fluid interface. Actually, it does the water entry nicely until there is a change in gamma around the extrusion layer. Once that happens, pd gets funky in that region, and the solution crashes pretty quickly. I'll see about posting the case (it's small) in a little bit.
Thanks,
Sean McIntyre
Solid/liquid phase change fabian_roesler OpenFOAM 10 December 24, 2012 06:37
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 10:46
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Change mesh topology during transient run Alex77 CFX 2 October 31, 2007 02:35
Topology change? ccc FLUENT 0 December 10, 2003 03:55
