particle tracing
Old   November 13, 2009, 03:22
Default particle tracing
X.G. Li
CYMa is on a distinguished road
i am new in applying OpenFOAM.
May somebody tell me which FOAM i should use to simulate particle tracing in a gas flow (no chemical reaction between particles and gas).
Thank you very much!!!
CYMa is offline   Reply With Quote
Old   November 13, 2009, 14:24
Andrew Ryan
andrewryan is on a distinguished road
Hi
Reading Nikas Nordin's thesis is a good start [1]. Then you should try out icoLagrangianFoam [2] If you want to learn the details about how lpt works in OpenFOAM read. [3] There are already some interesting posts on this forum, search for lagrangian or particle tracking.
Nils
[1] http://powerlab.fsb.hr/ped/kturbo/Op...sNordinPhD.pdf
[2] http://openfoamwiki.net/index.php/Co...LagrangianFoam
[3] http://www.cfd-online.com/Forums/ope...mentation.html
andrewryan is offline   Reply With Quote
Old   November 18, 2009, 13:12
Assistant Moderator
Bernhard Gschaider
Originally Posted by andrewryan View Post
Hi
Nils
I would discourage the usage of icoLagrangianFoam. It is sooo pre-1.5 (in 1.5 the particle system changed a lot and there are lagrangian-solvers that come with the distribution (some of them in the tutorials). ILF compiles on 1.5, but is not state of the art)
Bernhard
Old   November 19, 2009, 02:47
Andrew Ryan
What pieces of code would you recommend instead? dieselFoam?
Old   November 19, 2009, 04:29
Assistant Moderator
Bernhard Gschaider
The last time I looked at it, it was "old school". Have a look at the solvers in $FOAM_SOLVERS/lagrangian (and there are additional solvers in $FOAM_TUTORIALS/lagrangian). If you're lucky you'll find an intermediate-class that fits your need and which you just have to plug into your solver
Bernhard
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
[General] Paraview PARTICLE TRACING simone Marras ParaView 0 March 2, 2007 07:01
Particle track files Sankalp CFX 1 August 25, 2004 23:25
the separated particle temperature in cyclone mkuswadi FLUENT 0 December 17, 2003 08:25
Particle tracing and Re Jackie CFX 8 August 11, 2003 23:12
