October 18, 2009, 22:41 |
mapfields
sarangarajan
Rep Power: 16 |
hi.. please tell me if my understanding is correct.
a.In map fields utility if we have same dimensions in the case files , for instance if i have the same geometry in both the cases the [mapfields -consistent] is used and I get the fields imported to the destination from source. b. if i have a different geometry the keyword patchmap is used to map fields for patches that are co incident 'or' similar to the source file geometry c. if a portion of geometry in the destination case does not coincide those patches are mentioned under cuttingPatches |
MapFields only on internal fields | cosimobianchini | OpenFOAM Pre-Processing | 5 | May 5, 2020 06:08 |
mapFields ignores sourceTime for -parallel source | andersking | OpenFOAM Bugs | 2 | September 2, 2009 10:38 |
mapFields between inconsistent meshes | nikwin | OpenFOAM Pre-Processing | 7 | July 30, 2009 04:35 |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 14:17 |
MapFields | cpplabs | OpenFOAM Running, Solving & CFD | 3 | February 17, 2008 05:08 |
