October 31, 2009, 18:28 |
Stop Openfoam simulation
n/a
evening everyone. does anyone know the command to stop an openfoam simulation/
October 31, 2009, 19:44 |
#2 | |
Alberto Passalacqua
Rep Power: 36 |
stopAt writeNow; // It stops the simulation after writing data for the current time step or stopAt noWriteNow; // It stops the simulation without writing data for the current time step in the controlDict dictionary and save it. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
October 31, 2009, 19:45 |
Paul Schiefer
November 1, 2009, 09:47 |
#4 | |
Mark Olesen
Rep Power: 40 |
From the command-line, a simple "touch ABORT" suffices without needing to edit any files. For general reference (in case anyone else wants to add it to their solvers): Before the time-loop begins: Code:
// define ABORT file for stopping the job fileName abortName(args.rootPath()/args.globalCaseName()/"ABORT"); if (isFile(abortName)) { Info<< "removing old ABORT file" << endl; rm(abortName); } Code:
if (isFile(abortName)) { Info<< "reacting to user ABORT" << endl; runTime.writeAndEnd(); } Code:
// cleanup ABORT file if (isFile(abortName)) { rm(abortName); } /mark |
August 8, 2011, 05:56 |
#5 | |
Quang
This is my code if( errors <= 0.001 ) { Info<< "reached convergence"<< endl; runTime.writeAndEnd(); Info<< "latestTime = " << runTime.timeName() << endl; } This is error -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 27921 on node dfmserver exited on signal 11 (Segmentation fault). -------------------------------------------------------------------------- |
July 13, 2012, 19:06 |
What could be the reason for OF not stopping when I put "writeNow" in the controldict file?
application pimpleFoam; startFrom startTime; startTime 0; stopAt writeNow; endTime 100; deltaT 0.002059; writeControl timeStep; writeInterval 1000; |
July 14, 2012, 01:20 |
runTimeModifiable yes; |
July 15, 2012, 07:54 |
A_R
July 15, 2012, 10:08 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Uhm... that only suspends the execution. Running: Code:
fg #or bg For more, search online for: Code:
linux job control Last but not least, nowadays the official OpenFOAM version has a helper script named foamEndJob. For more: Code:
foamEndJob -help Bruno
September 18, 2012, 11:58 |
Manfredi
Hello, what if i want to stop a process without losing saved data and then restart it from where i stopped it?
September 18, 2012, 14:44 |
#11 | |
Bruno Santos
Rep Power: 128 |
Greetings Meltedbrain,
Like I wrote on the previous post, the command foamEndJob can assist you with stopping it. As for restarting... you can see on the user guide, section 4.3 Time and data input/output control: Quote:
Bruno
September 19, 2012, 03:47 |
#12 |
Manfredi
Thank you sir,
so maybe i should set starfFrom:latestTime, right? |
August 25, 2020, 11:33 |
#13 |
Patti Michelle Sheaffer
Rep Power: 7 |
Is OpenFOAM appropriate for a river simulation | jasonneuswanger | OpenFOAM Running, Solving & CFD | 8 | December 18, 2020 04:25 |
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 18:28 |
Solidification simulation with OpenFOAM | James | OpenFOAM | 5 | June 26, 2012 02:33 |
diesel Engine simulation in OpenFOAM | karam | OpenFOAM Running, Solving & CFD | 1 | March 1, 2011 09:46 |
OpenFOAM Training Courses in Germany | hjasak | OpenFOAM Announcements from Other Sources | 0 | July 23, 2009 19:34 |
