November 17, 2009, 00:15 |
Problem with paraFoam
ata kamyabi
Hi foamers
I have som problem with paraFoam. When I run it I get this message: "created temporary 'cavity.OpenFOAM' /home/ata/OpenFOAM/OpenFOAM-1.6/bin/paraFoam: 132: paraview: not found" Can any one help me? Thanks Ata |
November 17, 2009, 00:30 |
ata kamyabi
Hi
I try to recompile paraView from source but when I run makeParaViewI get this message: "command not found" My qt version is "QMake version 2.01a, Using Qt version 4.3.4 in /usr/lib" Can any one help me? Thanks Ata |
November 18, 2009, 00:42 |
ata kamyabi
Hello Bruno
Thanks for your reply. My qt version is 4.3.4 is it low? When I try makeParaView in spite of the fact that the makeParaView exists in related folder but I got this message "command not found" Can you or any one help me? Thanks allot Ata |
November 18, 2009, 08:55 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hello Ata,
I forgot to comment about that... to run scripts from a local folder, usually you have to use "./". For your case: Code:
./makeParaView Don't forget to follow the instructions I left on the other post! Best regards, Bruno |
November 21, 2009, 00:54 |
ata kamyabi
Hello Bruno
Thank you very much. I am trying. It takes much time to "./makeParaView". I'll inform you. Thanks allot Ata |
November 21, 2009, 07:05 |
ata kamyabi
Hello Bruno
Thanks for your reply. I run ./makeParaView after couple of hours it don.First time paraview run but not correctly. It's weird but menus and screen disappeared chaotic. When I restart my computer and run it for second time first its starting window come on but after few seconds I got this message in terminal: Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". ERROR: In /home/ata/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 405 vtkXOpenGLRenderWindow (0x88d8ec8): Could not find a decent visual Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". ERROR: In /home/ata/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 405 vtkXOpenGLRenderWindow (0x88d8ec8): Could not find a decent visual ERROR: In /home/ata/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 612 vtkXOpenGLRenderWindow (0x88d8ec8): GLX not found. Aborting. Aborted Can you or any body help me? Thanks allot Ata |
November 21, 2009, 07:29 |
andy
Rep Power: 18 |
It is telling you that it cannot set your computer to an acceptable OpenGL mode. This may be because you have very old graphics hardware with poor OpenGL support or because you have not yet installed on your system some of the required OpenGL software. What computer are using and what operating system?
November 21, 2009, 07:49 |
Problem with ParaView
ata kamyabi
Hello andy
Thanks for your reply My computer is: CPU:Intel Celeron 2.40GHz VGA:RADEON 7000 RAM: 512 MB My operating system is ubuntu 8.04 Thanks Ata |
November 21, 2009, 09:45 |
andy
Rep Power: 18 |
That looks like an ATI graphics card. You probably need to install the linux opengl glx software for your card. For NVIDIA cards these are identifiable software packages in synaptic which you can simply select and install. I don't know about ATI cards and so would suggest checking the ATI site for linux/opengl support and browsing synaptic for a likely looking generic opengl glx package.
November 21, 2009, 12:42 |
Priblem with paraview
#11 |
ata kamyabi
Hello Andy
Thank you very much Best regards Ata |
November 29, 2009, 02:10 |
Problem with paraview
#12 |
ata kamyabi
Hi foamers
When I installed paraview on a new computer via synaptick pakage manager an run I got this error: paraview: /home/ata/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux/lib/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtksys.so.pv3.4) Can any one help me? Regards Ata |
November 29, 2009, 04:45 |
#13 |
ata kamyabi
Hi foamers
When I compile paraview on a new computer it worked but I got this message in terminal: X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 Generic Warning: In /home/ata/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Filtering/vtkPolyLine.cxx, line 196 Coincident points in polyline...can't compute normals X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 When I get screen shot in paravie I get this message: X Error: GLXBadContextTag 170 Extension: 153 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x4600693 Can any one help me? Regards Ata Last edited by ata; November 29, 2009 at 05:01. |
November 29, 2009, 18:01 |
#14 | |
Bruno Santos
Rep Power: 128 |
Hello Ata,
Ouch, you're not having much luck with Paraview... Quote:
As for your latest problem, try what I've already said in this thread. And did you try the same solution you used with the other machine, the one you had in post #9? Best regards, Bruno |
November 30, 2009, 04:23 |
#15 |
ata kamyabi
Hi Bruno
Thank you very much. No I got this error on an other machine. Best Regards Ata |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
[OpenFOAM] paraFoam problem | autumn1012 | ParaView | 22 | July 8, 2010 02:20 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
