September 1, 2010, 05:05 |
Spring problem
mikael
Rep Power: 15 |
Hi OpenFOAMers,
I'm working on a floating dock simulation exposed to heave using interDyMFoam from the version OF 1.7. To simulate bollards I used spring which allows me to determine stress on bollards. At first I used velocityLaplacian in dynamicMeshDict and I put my spring condition in the pointMotionU file. The floating body simulation is good but the motion due to spring is not correct. So I replaced velocityLaplacian by displacementLaplacian and I changed the pointMotionU file by pointDisplacement. I restarted the simulation and now it is the floatingBody results which are falses. The linear velocity components become too larges in some time steps. If I put smaller constants on the dock (mass, moment of inertia) the simulation works with displacementLaplacian. So how can I couple the floating body simulation with a spring expression? Thanks in advance. Keul |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
