Diego Villa
Rep Power: 16 ![]() |
Hello
I'm a new OpenFoam user and developper. I'm trying to make a simulation of a floating object in to the wather. I use the interFoam solver (with OF1.6), with the k-e modell for the turbulen. I set all the fields, in particular alpha1 to set the initial free surface position with (setFields). I need to set the hydrostatic pressure (non p equal 0 in all the domain) at the fist time, because the solver crash after 3 iteration. Can some one tell me how can I do this? Thanks a lot. Diego |
Christian Kröner
you could use funkySetFields for example: http://openfoamwiki.net/index.php/Co...funkySetFields in 5.1 it is described how to initialise a pressure field gradient due to gravity. ckroener |
Diego Villa
Thank you Christian
Diuring the eastert holidays i'll try this. To run my simulation it is right that i must use: 1. interFoam as solver for incompressible rans bi-phase immiscible 2. funkySetFields for set the initial condition 3. GroovyBC for the boudary condition for alpha1, p, and U, k, e for the inlet 4. and to have a no reflecting condition as outlet what can I use? Thanks again. |
pressure, setfields, static |
Problem running buoyantFoam | anke | OpenFOAM | 4 | August 28, 2013 04:43 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
AMG versus ICCG | msrinath80 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2006 15:15 |
Automatic Mesh Motion solver | michele | OpenFOAM Running, Solving & CFD | 10 | September 26, 2005 08:21 |
