Compiling new Solver with wmake
Old   April 13, 2010, 06:30
Default Compiling new Solver with wmake
Lin Möllenhoff
lin123 is on a distinguished road
Hello together,
I want to simulate the air flow around and through a car. As the model contains porous zones I added the porousSimpleSolver to my OpenFoam installation.
/home/user/OpenFOAM/OpenFOAM-1.6/applications/solvers/incompressible/porousSimpleFoamLin
I did this solver using the SimpleFoam solver and the porous medium module from the compressible rhoPorousSimpleFoam solver and the help of a few documents I found on the web.
When I am compiling this new solver with wmake as described in the user guide, I get a huge number of errors. The strange thing is hat I get nearly the same errors when I try to compile an existing solver!
Here is what I get:
ares:/home/user/OpenFOAM/OpenFOAM-1.6/applications/solvers/incompressible/porousSimpleFoamLin # wmake
SOURCE=porousSimpleFoam.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/home/user/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels -I/home/user/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/incompressible/RAS/RASModel -I/home/user/OpenFOAM/OpenFOAM-1.6/src/transportModels -I/home/user/OpenFOAM/OpenFOAM-1.6/src/transportModels/incompressible/singlePhaseTransportModel -I/home/user/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/user/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/porousSimpleFoam.o
/home/user/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readSIMPLEControls.H: In function int main(int, char**):
/home/user/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readSIMPLEControls.H:6: warning: unused variable momentumPredictor
/home/user/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readSIMPLEControls.H:9: warning: unused variable fluxGradp
/home/user/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readSIMPLEControls.H:12: warning: unused variable transonic
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/home/user/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels -I/home/user/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/incompressible/RAS/RASModel -I/home/user/OpenFOAM/OpenFOAM-1.6/src/transportModels -I/home/user/OpenFOAM/OpenFOAM-1.6/src/transportModels/incompressible/singlePhaseTransportModel -I/home/user/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/user/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude   -fPIC Make/linux64GccDPOpt/porousSimpleFoam.o -L/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt \
             -lincompressibleRASModels -lincompressibleTransportModels -lfiniteVolume -lOpenFOAM -liberty -ldl   -lm -o /home/user/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/porousSimpleFoam
/usr/bin/ld: warning: libincompressibleTurbulenceModel.so, needed by /home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libmeshTools.so, needed by /home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libtriSurface.so, needed by /home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libPstream.so, needed by /home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so, not found (try using -rpath or -rpath-link)
Make/linux64GccDPOpt/porousSimpleFoam.o: In function `Foam::PtrList<Foam::porousZone>::~PtrList()':
porousSimpleFoam.C:(.text._ZN4Foam7PtrListINS_10porousZoneEED2Ev[Foam::PtrList<Foam::porousZone>::~PtrList()]+0x49): undefined reference to `Foam::coordinateSystem::~coordinateSystem()'
porousSimpleFoam.C:(.text._ZN4Foam7PtrListINS_10porousZoneEED2Ev[Foam::PtrList<Foam::porousZone>::~PtrList()]+0xdd): undefined reference to `Foam::coordinateSystem::~coordinateSystem()'
Make/linux64GccDPOpt/porousSimpleFoam.o: In function `Foam::fvMatrix<double>::setReference(int, double const&, bool)':
porousSimpleFoam.C:(.text._ZN4Foam8fvMatrixIdE12setReferenceEiRKdb[Foam::fvMatrix<double>::setReference(int, double const&, bool)]+0x15d): undefined reference to `Foam::IPstream::read(Foam::Pstream::commsTypes, int, char*, long)'
porousSimpleFoam.C:(.text._ZN4Foam8fvMatrixIdE12setReferenceEiRKdb[Foam::fvMatrix<double>::setReference(int, double const&, bool)]+0x19d): undefined reference to `Foam::OPstream::write(Foam::Pstream::commsTypes, int, char const*, long)'
porousSimpleFoam.C:(.text._ZN4Foam8fvMatrixIdE12setReferenceEiRKdb[Foam::fvMatrix<double>::setReference(int, double const&, bool)]+0x1e8): undefined reference to `Foam::IPstream::read(Foam::Pstream::commsTypes, int, char*, long)'
porousSimpleFoam.C:(.text._ZN4Foam8fvMatrixIdE12setReferenceEiRKdb[Foam::fvMatrix<double>::setReference(int, double const&, bool)]+0x21d): undefined reference to `Foam::OPstream::write(Foam::Pstream::commsTypes, int, char const*, long)'
porousSimpleFoam.C:(.text._ZN4Foam8fvMatrixIdE12setReferenceEiRKdb[Foam::fvMatrix<double>::setReference(int, double const&, bool)]+0x3b5): undefined reference to `Foam::IPstream::read(Foam::Pstream::commsTypes, int, char*, long)'
porousSimpleFoam.C:(.text._ZN4Foam8fvMatrixIdE12setReferenceEiRKdb[Foam::fvMatrix<double>::setReference(int, double const&, bool)]+0x3f5): undefined reference to `Foam::OPstream::write(Foam::Pstream::commsTypes, int, char const*, long)'
porousSimpleFoam.C:(.text._ZN4Foam8fvMatrixIdE12setReferenceEiRKdb[Foam::fvMatrix<double>::setReference(int, double const&, bool)]+0x440): undefined reference to `Foam::IPstream::read(Foam::Pstream::commsTypes, int, char*, long)'
porousSimpleFoam.C:(.text._ZN4Foam8fvMatrixIdE12setReferenceEiRKdb[Foam::fvMatrix<double>::setReference(int, double const&, bool)]+0x47d): undefined reference to `Foam::OPstream::write(Foam::Pstream::commsTypes, int, char const*, long)'
Make/linux64GccDPOpt/porousSimpleFoam.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate()':
porousSimpleFoam.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField8evaluateEv[Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate()]+0x349): undefined reference to `Foam::IPstream::waitRequests()'
porousSimpleFoam.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField8evaluateEv[Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate()]+0x351): undefined reference to `Foam::OPstream::waitRequests()'
Make/linux64GccDPOpt/porousSimpleFoam.o: In function `Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate()':
porousSimpleFoam.C:(.text._ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField8evaluateEv[Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate()]+0x349): undefined reference to `Foam::IPstream::waitRequests()'
porousSimpleFoam.C:(.text._ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField8evaluateEv[Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate()]+0x351): undefined reference to `Foam::OPstream::waitRequests()'
Make/linux64GccDPOpt/porousSimpleFoam.o: In function `Foam::DimensionedField<double, Foam::volMesh>::weightedAverage(Foam::DimensionedField<double, Foam::volMesh> const&) const':
porousSimpleFoam.C:(.text._ZNK4Foam16DimensionedFieldIdNS_7volMeshEE15weightedAverageERKS2_[Foam::DimensionedField<double, Foam::volMesh>::weightedAverage(Foam::DimensionedField<double, Foam::volMesh> const&) const]+0x9c): undefined reference to `Foam::reduce(double&, Foam::sumOp<double> const&)'
porousSimpleFoam.C:(.text._ZNK4Foam16DimensionedFieldIdNS_7volMeshEE15weightedAverageERKS2_[Foam::DimensionedField<double, Foam::volMesh>::weightedAverage(Foam::DimensionedField<double, Foam::volMesh> const&) const]+0x11f): undefined reference to `Foam::reduce(double&, Foam::sumOp<double> const&)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::operator<<(Foam::Ostream&, Foam::wallPoint const&)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::cellDistFuncs(Foam::polyMesh const&)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `vtable for Foam::OPstream'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::OPstream::~OPstream()'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::cellDistFuncs::correctBoundaryFaceCells(Foam::HashSet<int, Foam::Hash<int> > const&, Foam::Field<double>&, Foam::Map<int>&) const'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::incompressible::turbulenceModel::correct()'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::cellDistFuncs::cellDistFuncs(Foam::polyMesh const&)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::IPstream::IPstream(Foam::Pstream::commsTypes, int, int, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::faceSet::faceSet(Foam::polyMesh const&, Foam::word const&, Foam::HashSet<int, Foam::Hash<int> > const&, Foam::IOobject::writeOption)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::directMappedPatchBase::sampleMesh() const'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::exit(int)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::coordinateSystem::coordinateSystem(Foam::word const&, Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::Vector<double> const&)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::cellSet::cellSet(Foam::polyMesh const&, Foam::word const&, int, Foam::IOobject::writeOption)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::triSurfaceTools::calcInterpolationWeights(Foam::triSurface const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::FixedList<int, 3u> >&, Foam::List<Foam::FixedList<double, 3u> >&)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::directMappedPatchBase::calcMapping() const'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::cellSet::~cellSet()'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::smallestDist(Foam::Vector<double> const&, Foam::polyPatch const&, int, Foam::List<int> const&, int&) const'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::incompressible::turbulenceModel::turbulenceModel(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::faceSet::faceSet(Foam::polyMesh const&, Foam::word const&, int, Foam::IOobject::writeOption)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::getPointNeighbours(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, int, Foam::List<int>&) const'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::directMappedPolyPatch::typeName'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::triSurface::write(Foam::fileName const&, bool) const'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::wallPoint::greatPoint'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::patchWave::patchWave(Foam::polyMesh const&, Foam::HashSet<int, Foam::Hash<int> > const&, bool)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::abort()'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::faceSet::~faceSet()'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::operator>>(Foam::Istream&, Foam::wallPoint&)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::cellDistFuncs::getPatchIDs(Foam::word const&) const'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::incompressible::turbulenceModel::typeName'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::coordinateSystem::coordinateSystem(Foam::dictionary const&, Foam::objectRegistry const&)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::patchWave::~patchWave()'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `typeinfo for Foam::directMappedPatchBase'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `typeinfo for Foam::directMappedPolyPatch'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::triSurface::~triSurface()'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::topoSetSource::New(Foam::word const&, Foam::polyMesh const&, Foam::dictionary const&)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::coordinateSystem::writeDict(Foam::Ostream&, bool) const'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::cellDistFuncs::correctBoundaryPointCells(Foam::HashSet<int, Foam::Hash<int> > const&, Foam::Field<double>&, Foam::Map<int>&) const'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::incompressible::turbulenceModel::turbulenceModelConstructorTablePtr_'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::directMappedPatchBase::typeName'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::triSurfaceTools::delaunay2D(Foam::List<Foam::Vector2D<double> > const&)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::maxPatchSize(Foam::HashSet<int, Foam::Hash<int> > const&) const'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::incompressible::turbulenceModel::constructturbulenceModelConstructorTables()'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::init(int&, char**&)'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::incompressible::turbulenceModel::destroyturbulenceModelConstructorTables()'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined reference to `Foam::cellDistFuncs::sumPatchSize(Foam::HashSet<int, Foam::Hash<int> > const&) const'
/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::addValidParOptions(Foam::HashTable<Foam::string, Foam::word, Foam::string::hash>&)'
collect2: ld returned 1 exit status
make: *** [/home/user/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/porousSimpleFoam] Fehler 1
I am using OpenFoam 1.6 with gcc version 4.3.3. I am new to OpenFoam and a beginner with Linux
I would be really thankful for a few advices.
Lin
lin123 is offline   Reply With Quote
Old   April 13, 2010, 08:27
romant's Avatar
Roman Thiele
romant is on a distinguished road
it can be that you are missing some of the packages required to compile OpenFOAM.
those here are just some of the packages needed
binutils-dev flex git git-core build-essential python-dev libqt4-dev libreadline5-dev wget zlib1g-dev cmake
if you are not sure about those, try using the install cookbook from the forum
http://www.cfd-online.com/Forums/ope...-cookbook.html
or those install scripts if u are using a debian based distribution http://hvirvel.dk/OF/ (they are actually taken from the initializer of the install cookbook
~roman
romant is offline   Reply With Quote
Old   April 13, 2010, 09:38
Lin Möllenhoff
Thanks for your reply!
Actually I am using SUSE Linux Enterprise Server(x86_64)
how to check which package is already installed!?
Old   April 13, 2010, 14:18
Default suse installation stuff
romant's Avatar
Roman Thiele
Hej,
in that case. Try using YAST. If I remember right, this is the installation tool of Suse. In that program you can search for packages and if they show up as not installed, you can install them.
If for some reason you only have command line access, http://en.opensuse.org/Software_Mana...ine_Comparison here are some tips on how to install packages commandline style with suse.
~roman
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 13:28
