BC for temperature added to interFoam
Old   April 22, 2010, 08:47
Exclamation BC for temperature added to interFoam
Dan Gadensgaard
dgadensg is on a distinguished road
Hi all.
I have, almost succesfully, implemented the temperature equation in the interFoam solver for simulationg the filling stage of injection moulding.
My problem is that the solver crashes when the mold is almost filled. as shown on the picture below:
The end patches left and right are defined as zeroGradient for both velocity U, temperature T, and volumefraction alpha. The pressure p is defined as fixedvalue 0.
The error message is shown below:
Courant Number mean: 0.00623793 max: 0.495492
deltaT = 9.80392e-05
Time = 0.6
MULES: Solving for alpha1
Opnået 0.962465/98 pct. fyldning.
DILUPBiCG:  Solving for T, Initial residual = 0.00029924, Final residual = 2.10118e-08, No Iterations 1
DICPCG:  Solving for p, Initial residual = 2.94435e-05, Final residual = 8.68614e-08, No Iterations 56
time step continuity errors : sum local = 1.39854e-09, global = -1.18444e-12, cumulative = -0.00169153
ExecutionTime = 709.3 s  ClockTime = 721 s
End
#0  Foam::error::printStack(Foam::Ostream&) in "/home/dang/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigSegv::sigSegvHandler(int) in "/home/dang/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  ?? in "/lib/libc.so.6"
#3  Foam::IOobject::~IOobject() in "/home/dang/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#4  Foam::regIOobject::~regIOobject() in "/home/dang/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#5  Foam::twoPhaseMixture::~twoPhaseMixture() in "/home/dang/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interTempFoam"
#6  main in "/home/dang/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interTempFoam"
#7  __libc_start_main in "/lib/libc.so.6"
#8  _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116
Segmentation fault
Hope someone can help me with an answer.
// Dan G
dgadensg is offline   Reply With Quote
Old   April 22, 2010, 10:27
Stefan Herbert
herbert is on a distinguished road
Hi Dan,
I'm a little bit confused about your error massage, because the error seems to happen after the simulation is finished (just because there is displayed "End" in front of the error message). Or did you add some code under this command?
herbert is offline   Reply With Quote
Old   April 22, 2010, 15:16
Dan Gadensgaard
Hi herbert.
I do not know why it prints out "end", because the simulation is programmed to stop as soon as the mold is 98 percent filled.
I have tried to run the same case with the standard interFoam solver, and it works fine.
the problem is also occuring for other cases where as soon as the polymer phase reaches an outlet, the solver stops.
// Dan
boundary condition, interfoam, temperature
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 9 July 25, 2020 06:36
How can Temperature be added into interFoam ttdtud OpenFOAM Running, Solving & CFD 14 September 7, 2013 07:32
Moving from simpleFoam to interFoam with alpha = 0 kjetil OpenFOAM Running, Solving & CFD 1 November 8, 2009 20:04
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
Question on InterFoam moving mesh capabilities ziv OpenFOAM Running, Solving & CFD 0 April 23, 2008 09:11
