Species Specific Fields
Old   July 14, 2010, 15:06
Default Species Specific Fields
Daniel
hyperion is on a distinguished road
Hi Foamers - Does anyone know if there is a utility or other method that would allow me to view results for individual species? Specifically, I would like to know velocity and density profiles for different species in a flow.
Also, does anyone know if there is a utility that outputs local Knudsen and Courant numbers (on a cell by cell basis)?
Thanks for any and all help.
hyperion is offline   Reply With Quote
Old   July 15, 2010, 06:26
Hassan Kassem
hk318i is on a distinguished road
Dear hypersion,
if you are modeling single phase flow, it is impossible to calculate the velocity and density of each species. To do that you should use the a momentum equation for each specie.
I think you are modeling something special not just single phase flow because you are asking about Knudsen number. It will be better to give a brief about your case.
Regards,
Hassan
hk318i is offline   Reply With Quote
Old   July 15, 2010, 15:53
Daniel
Hi Hassan - Thanks for replying. I am trying to run the dsmcFOAM application. The case involves a vapor of one species expanding into low pressure inert gas of another species. I would like to know the velocity and density, or at least concentration, of the expanding gas. This is an application of rarefied gas dynamics, which is why I would also like to know local Knudsen numbers. Thanks again.
Old   July 15, 2010, 16:17
Hassan Kassem
Unfortunately I have no experience with dsmcFoam. I felt that you are doing something like that but your title and question was not clear enough.
I think it is now clear and I hope some dsmc foamer will help you soon. :-)
Old   May 2, 2018, 08:27
Default Concentration
Sadegh
Sadegh yousefi is on a distinguished road
Hi.do you know about calculation cancentration species in dsmcfoam?
Sadegh yousefi is offline   Reply With Quote
courant number, knudsen number, species
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
