May 14, 2010, 09:56 |
cylinder in crossflow...error...pls hlp
Snehal Janwe
Rep Power: 16 |
Hello everybody,
I am very new OpenFoam user and am trying to simulate vortex shedding of a cylinder in crossflow. As of now I have started the case with simplefoam which solves for first 4 timesteps and then crashes giving the following error: #0 Foam::error:rintStack(Foam::Ostream&) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam:ILUPreconditioner::calcReciprocalD(Foam::Fi eld<double>&, Foam::lduMatrix const&) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam:ILUPreconditioner:ILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::dictionary const&) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #5 Foam::lduMatrix:reconditioner::addasymMatrixCons tructorToTable<Foam:ILUPreconditioner>::New(Foam ::lduMatrix::solver const&, Foam::dictionary const&) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #6 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #8 Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/simpleFoam" #9 main in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/simpleFoam" #10 __libc_start_main in "/lib64/libc.so.6" #11 _start at /usr/src/packages/BUILD/glibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 Gleitkomma-Ausnahme I dont at all understand what this error means. It would be kind enough if you could enlighten me. Thanks |
Heat transfer of a cylinder in crossflow | aloha5i | Main CFD Forum | 6 | December 8, 2023 13:26 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
related to crossflow over a cylinder | Jibran Haider | FLUENT | 0 | July 9, 2008 00:12 |
