Methane combustion at atmospheric pressure
Old   September 15, 2010, 14:12
Default Methane combustion at atmospheric pressure
N. A.
N. A. is on a distinguished road
Hello Foamers,
Has anyone used reactigFoam for Methane-Oxygen combustion. I am trying to simualte a methane oxygen flame under atmospheric pressure. There is an inlet for both methane and oxygen. The issue is it does not ignite, even though the initial temperature is about 1500 K.
I also tried using enthalpySource and somehow that also does not help igniting the mixture.
If anyone has simulated, then it would be help ful if you could share your casefiles and solvers.
Thanks,
Nir
N. A. is offline   Reply With Quote
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Lean swirled premixed combustion methane air bisounours FLUENT 0 July 4, 2007 06:52
How to model combustion with only methane stream? ligang zheng FLUENT 2 May 1, 2007 09:16
Methane combustion in gas burner Stefano CFX 1 June 7, 2005 02:12
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
